SCT TUNER - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
SCT TUNER
Old 10-03-2013, 08:15 PM
URDADDY's Avatar
URDADDY URDADDY is offline
URDADDY is starting off with a positive reputation.
SCT TUNER
Thoughts on the SCT for dpf delete. Rudy's diesel has some for $850 which isn't cheap but a lot better then $1400 plus for others. Not looking for a bunch more hp mostly just want the dpf delete.
Opinions are appreciated.
Old 10-03-2013, 08:47 PM
matted2thefloor's Avatar
matted2thefloor matted2thefloor is offline
matted2thefloor is starting off with a positive reputation.
As far as SCT goes...the tuner of choice seems to be the LiveWire. I bought one used but the USPS is taking forever to get it here. The LiveWire can accept up to 3 custom tunes as well. II was warned about the SF3 3015R tuners...seems like they have a tendency to fry PCMs during an upload...just some food for thought.
Hopefully mine will get here soon...
Old 10-03-2013, 08:58 PM
URDADDY's Avatar
Wow, I had not heard of them frying PCM's. Anyone else hear anything like that?
Old 10-10-2013, 05:19 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
Master of Strokes
weekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud ofweekendwarriorfsw32 has much to be proud of
Never heard of that and never had an issue with mine. Best thing I ever did was get rid of that DPF.
Old 10-10-2013, 08:03 PM
BigRick202's Avatar
BigRick202 BigRick202 is offline
BigRick202 is starting off with a positive reputation.
gearbox z has a dpf-r programmer that is much less and will do the trick nicely, I've used mine about 6 months and havn't had any trouble with it, I purchased the one with the 70hp economy tune and like it but some others don't but as far as deleting dpf IMO can't beat it for the price. I purchased mine through XDP. Oh they also have a proggramer that has several different preset power levels that you can do.
Old 10-11-2013, 09:35 AM
STROKINMY'08's Avatar
STROKINMY'08 STROKINMY'08 is offline
STROKINMY'08 is gaining momentum as a positive member of FTE.
I went thru the same thing.. every1 said SPARTAN/HS MINI MAX.. but didn't want to spend 1500-2000.. bc I just wanted the delete...and a little better mileage.. I got a SCT tsx 8900.. keep in mind im lifted 6' with 37's.. but I was getting 9-10 mpg before..now im at high 12's-13 mpg... so I'm happy with mine...
Old 10-12-2013, 10:39 PM
URDADDY's Avatar
Im lifted 5 and running 35's. I hate the darn DPF, took a 30 minute drive today just to regen so the truck would act right. Sooner I can get rid of the DPF the better.
Old 10-13-2013, 12:46 AM
yeah that was our problem too.. we would pick dinner up/or grocery shopping..pull into the yard.. REGEN TIME.. back on the road.. so if I could get rid of that problem.. make the truck run better..and a little better mpg... I couldn't pass it up!
Old 10-13-2013, 05:52 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
I have never heard of them frying a PCM, I have the Innovative tune package, which replaces the "canned tunes" and I also have 3 custom tunes form Gearhead. Truck runs great!
Old 10-22-2013, 06:04 PM
TruckGuy27's Avatar
TruckGuy27 TruckGuy27 is offline
TruckGuy27 is starting off with a positive reputation.
Quote:
so im basically in the same boat... I have an 08 350 supercab, just bought 4" flo-pro... im not really in the position to purchase a hs mini or spartan. i guess im basically in it for the delete. you recommend yours?
Old 10-23-2013, 11:01 AM
yeah I've been happy with mine...I lifted mine and lost a lot of power...plus I was tired of the regens.. looked at hs/Spartan.. 1600-2000 said f' that..I'm not looking to race or tear my truck up..I went with a used SCT tsx 8900 got the tuner for 700 GOT my power back..on the low end im getting 13.. but I've been getting 18 on the lie-o-meter.. so I'm around high 14's-15mpg so I'm pleased.. and you can go for more..it's just the more aggressive the tune the better MPG's
Old 10-27-2013, 01:15 PM
FordManiac88 FordManiac88 is offline
FordManiac88 is starting off with a positive reputation.
I just ordered the SCT 3015R and the dpf/cat delete pipe.
Installed it yesterday in my driveway......
It's insanity. It's like the engine has been replaced with a pissed off demonic beast.
Mpg have improved somewhat but I haven't calculated it yet.
The nice feature is no more regens, the engine and transmission seem to be working much better, the shifts are firmed up, it sounds amazing you can hear the turbo more and the growl is nice, no more oil being polluted with diesel, it disables the egr bullcrap and the best part is it haulllls ****ing ***. It's nothing to be cruising at 40km mash the gas and it'l get sideways with no strain at all.
Old 12-21-2013, 12:36 AM
dar1 dar1 is offline
dar1 is starting off with a positive reputation.
I am new to owning a diesel and I want to delete the DPF on my 08'. If I buy an SCT 8900 or 3015R, do I also have to by a custom tune for the DPF delete? Or is it included in the canned tunes?
Old 12-21-2013, 10:53 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Yup Ive got a 3015R the shop installed a 3015 the first time caused lots of problems , but got it straighted out.
Everyone here told me not to use a SCT , I never did find out why?
Its way cheaper and does what I want.
Old 12-22-2013, 01:01 AM
reaganla's Avatar
reaganla reaganla is offline
reaganla is gaining momentum as a positive member of FTE.
I love my SCT.. its the extreme race (hard to find now) but I've never herd of frying pcm. SCT also offers great customer service. Dsr1 you don't have to purchase anything additional... the tuner simply asks if you have dpf deleted, also asks if egr is deleted. You can recalculate tire size read and erase codes and monitor vitals that pcm provides. Hope this info is helpful
DPF/CAT Delete Tuner Opinions ,EGR Help? baja370 6.4L Power Stroke Diesel 1 10-21-2015 10:14 AM
DPF DELETE PROBLEM!!! FORDSUPERTRUCK 6.7L Power Stroke Diesel 12 07-15-2015 08:01 AM
Sct tuner 2008 6.4 TT diesel Tucks6.4powerhouse 6.4L Power Stroke Diesel 10 08-15-2014 09:28 PM
SCT TUNER/DPF DELETE??? STROKINMY'08 6.4L Power Stroke Diesel 6 07-18-2013 08:55 PM
SCT 9625OR cmalley12 6.4L Power Stroke Diesel 1 06-15-2012 03:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
