6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Grease Fittings location
Old 02-26-2012, 08:47 AM
chi6488's Avatar
chi6488
chi6488 is offline
Can someone be nice enough to photo and help me find the grease fittings I need to lube when oil changing??
I cannot find them
Old 02-26-2012, 02:04 PM
UGA33's Avatar
UGA33
UGA33 is offline
Only grease fittings on these trucks are on 4x4 trucks. There are two. One on each front axle shaft u joint.
Old 02-26-2012, 02:57 PM
longview1's Avatar
longview1
longview1 is offline
^ Didnt think there was any! Ill have to shoot a bit of grease in them two.
Old 02-26-2012, 04:02 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
Confirmed...only the two.
Old 08-17-2014, 10:18 AM
RM2738's Avatar
RM2738
RM2738 is offline
Been reading a few forums regarding retrofitting Zerks into non serviceable joints in other makes and models. Are there any joints on 2008-2010 SD's that one may consider doing such?
Old 08-17-2014, 08:49 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
When I had my 2001 F350 I had a vibration after replacing the U Joints in the driveshaft. Ended up taking it to get balanced, they would not touch it unless they replaced the joints with OEM type joints, called the grease-able joints junk, and that was that.
Old 08-18-2014, 04:58 AM
senix's Avatar
senix
senix is offline
I don't think I would touch them till needed. Then replace with grease able joints.
Powerstoke73
08-02-2014 04:00 PM
obscurity
08-26-2013 09:18 AM
aidandj
20
08-11-2013 11:13 AM
cpdorroh
2009 - 2014 F150
06-20-2009 09:42 AM
JohnAW
1983 - 2012 Ranger & B-Series
02-22-2005 08:05 AM
Quick Reply: Grease Fittings location
