SCT TUNER - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
SCT TUNER
Old 12-22-2013, 12:09 PM
Thasilver_6.7's Avatar
Thasilver_6.7 Thasilver_6.7 is offline
Thasilver_6.7 is gaining momentum as a positive member of FTE.Thasilver_6.7 is gaining momentum as a positive member of FTE.
the 8900 tsx I got came pre-loaded with tunes...so I would think they all do.. it will ask if the dpf is deleted...then the egr...blah blah it walks you through it.. in all honesty.. I went cheap with the sct.. CUSTOMER svc was great.. but my truck never seemed to shift right.. broke down bought a HS mini maxx the BEST THING I EVER DID... I run the 250hp tune... it shifts PERFECTLY... IMHO I would save a little extra go with a hs/Spartan...do it right the 1st time...you won't be disappointed
Old 12-22-2013, 12:25 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Quote:
There are many reputable tuners that have tunes for SCT devices, IDP, Gearhead are a few that I run and they know what they are doing. Each truck acts a little different and sometimes things need to be tweaked, Even with H&S and Spartan…..This is a very hot topic on every forum out there, opinions are like azz holes…everyone has one.
Old 12-26-2013, 08:15 AM
i agree I was just stating my 2cents worth...tried the sct.. it was decent... but right out of the box..straight hp..no custome tunes.. I think hs is the best.. my truck was shifting right in a day in a half.. the sct just never seemed to tune the tranny right... but as you stated we all have *******s and opinions.. try one if you don't like it...look to the next!
Old 08-12-2014, 09:19 AM
Tucks6.4powerhouse Tucks6.4powerhouse is offline
Tucks6.4powerhouse is starting off with a positive reputation.
Sct tuner
Quote:
Originally Posted by FordManiac88 View Post
I just ordered the SCT 3015R and the dpf/cat delete pipe.
Installed it yesterday in my driveway......
It's insanity. It's like the engine has been replaced with a pissed off demonic beast.
Mpg have improved somewhat but I haven't calculated it yet.
The nice feature is no more regens, the engine and transmission seem to be working much better, the shifts are firmed up, it sounds amazing you can hear the turbo more and the growl is nice, no more oil being polluted with diesel, it disables the egr bullcrap and the best part is it haulllls ****ing ***. It's nothing to be cruising at 40km mash the gas and it'l get sideways with no strain at all.
Is this the 3015r from rudys diesel? Are you running it on a 6.4 n what's your city mpg?
Old 08-12-2014, 09:21 AM
Act tuner
I'm thinking of getting the same kit. Did u delete the egr as well or just bypassing it with the tuner?
Old 08-12-2014, 12:01 PM
Sct tuner
Quote:
Also did u do the egr delete or just bypass it with the tuner?
Old 08-13-2014, 03:35 PM
WyoBlueF3's Avatar
WyoBlueF3 WyoBlueF3 is offline
WyoBlueF3 is starting off with a positive reputation.
All I wanted to do was delete the stupid exhaust plug also, so I bought the GearboxZ DPFr 4.0 direct from them for about $400 and got the block off plates for another 20. It was simple to load onto the ECM. The Banks Automind I have works with it. I recently took a 300 mile trip and calculated out 17 mpg. I am plenty pleased so far with it.
Just pluggin my .02.
Old 08-13-2014, 03:36 PM
WyoBlueF3's Avatar
not sure why that posted twice...only hit the post button once...
Old 08-17-2014, 10:44 PM
1999stroke 1999stroke is offline
1999stroke is gaining momentum as a positive member of FTE.
what size tires do you guys have on your trucks cause I have a sct live wire with dpf delete and I cant get better than 12 mpg it is a 2010 f250 crew cab short bed 4x4 with a leveling kit and 35's
Old 08-18-2014, 07:10 AM
37x13.50x20 for me... I'm getting 12-13 mpg's in the city... An Intake might net you another 1-2 mpg.. how big/wide are your rims? I always thought that what I was getting was fine for 6' suspension/37's AS I've SAID BEFORE MILEAGE IS A TOUCHY SUBJECT....because you hear a lot of "claims"
Old 08-19-2014, 06:31 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
Those big tires and 4 WD are killing you guys, I get 16-18 in the city regularly.
Not a claim, it's a fact.
Old 08-19-2014, 12:01 PM
lol....bubba that's not hard 2 believe because of your set-up...it's the guys that have 35's or the same set up as me claiming the same numbers your getting! I still don't get why guys complain about the mileage...it's an 8k truck...for me a little heavier...as long as my truck doesn't let me down...I'll be fine stopping to get diesel every few days
  #28
Old 08-19-2014, 06:24 PM
bubbasz1's Avatar
I have to agree, big tire, 8,000Lbs, semi heavy foot, 12 MPG is pretty respectable.
My poor truck is dying to go on a road trip or something, they've had the freeway closed since before spring, been taking the side roads to work, I'm sure she would like to go out and blow out some cob webs.
DPF/CAT Delete Tuner Opinions ,EGR Help? baja370 6.4L Power Stroke Diesel 1 10-21-2015 09:14 AM
DPF DELETE PROBLEM!!! FORDSUPERTRUCK 6.7L Power Stroke Diesel 12 07-15-2015 07:01 AM
Limiter Vinford 6.4L Power Stroke Diesel 10 09-27-2014 05:40 PM
Sct tuner 2008 6.4 TT diesel Tucks6.4powerhouse 6.4L Power Stroke Diesel 10 08-15-2014 08:28 PM
SCT TUNER/DPF DELETE??? Thasilver_6.7 6.4L Power Stroke Diesel 6 07-18-2013 07:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
