292 craking power - Ford Truck Enthusiasts Forums
292 craking power
Old 10-03-2013, 06:52 PM
Rmc292 Rmc292 is offline
Rmc292 is starting off with a positive reputation.
292 craking power
I have had this issue for some time now. Where the engine cranking power is so low that it will barely turn the engine over (will not start). I have tried to jump it and it acts the same. Could it be that the starter has a problem? I have a 272 and a 292 and they both do the same thing. I'm using the same starter on both.
Has anyone seen this before?
Thanks,
Old 10-03-2013, 08:43 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
Thanks,
Howdy,
Well,
It's most likely a starter motor or starter electrical circuit problem.
If the start motor is faulty, you need to either get another one or get that one rebuilt.
If the starter circuit is faulty, it could be the battery or associated connections including the ground wire, ground strap, start solenoid, or any connection associated with starter.
You'll just have to trouble shoot it.
Regards,
Rick
Old 10-17-2013, 11:13 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
A starter that's going bad will draw a lot of current, and do what you describe. So can a loose or corroded connection(s) at the battery terminals, starter, ground straps, etc. And if you're having any kind of starting problems and troubleshooting issues, you are torturing your battery! Put it on the charger every night till you fix the underlying, your wallet will thank you.
Old 12-21-2013, 10:18 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
You say you have the same problem with two different vehicles? That is odd, but these have been around longer than most people posting in this thread. Time to check everything, including ground wires. Take everything apart, check resistance in the wires, clean until everything is spotless and then clean some more. You may be looking at a little here and a little there adding up to a lot as an end result.
BTW what do you set your timing at? Too much advance can make this happen but it's usually only when the vehicle is warm
Old 12-22-2013, 08:32 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
In case you have a 6 volt system, using a 12 volt starter would cause that.
Old 12-22-2013, 10:04 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Look up "starter voltage drop test."
Crunch Time Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 2 09-11-2016 01:28 AM
64 292/AT Shadowrider123 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 02-25-2016 11:11 PM
292 in school bus question anthony myrick Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 02-11-2016 12:10 PM
292 or????? SIXTFOR 1961 - 1966 F-100 & Larger F-Series Trucks 40 09-24-2015 04:26 PM
292 Starter Rusty_S Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 22 02-08-2015 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
