02 F450 No Crank No Start
2002 F450 7.3 Turbo
Ok first problem
Starter Motor fuse kept blowing and I spent weeks trying to figure it out. No luck. so wired up a push button just to get the truck started, its a work truck so it was needed asap.
2nd problem
the truck stopped starting completely. Wont start in Park or neutral and after a NEW STARTER (because I thought the solenoid on the starter was bad I replaced it) Everything work correctly for one start with the key. after the second time trying to start it blew the starter fuse again. So i tried the straight wiring to starter. still nothing. I was wondering if there are any shims or anything at the transmission housing to correctly position the starter. Im thinking that maybe the gear is stuck or gets stuck sometimes. when I straight wire the starter it does nothing but the wire gets hot so I know its pulling.
Please help.
Ok first problem
2nd problem
Please help.
Fal Grunt
04-30-2008 08:11 PM
