What did you do to your IDI today? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 07-17-2014, 07:06 AM
3KP's Avatar
3KP 3KP is offline
3KP is starting off with a positive reputation.
Yesterday I received all my order partss. New Delphi Injectors, New return line kit, New ZD9 glow plugs and New GP Relay. Went out to the truck removed old return lines and already have the new ones cut and ready to go back in. (was shorted 2 clamps so need to got to the auto store to get those) Sprayed down injectors and glow plugs with PB Blaster hopefully today after work I will be changing out my parts. Never done this before little nervous and excited the same time. Wish me luck!
  #62
Old 07-17-2014, 07:14 AM
jayro88 jayro88 is offline
jayro88 is gaining momentum as a positive member of FTE.
Good luck. Should be pretty easy.
  #63
Old 07-17-2014, 10:08 PM
3KP's Avatar
3KP 3KP is offline
Well continue with my day. I got home later from work than expected had one of my service calls go sideways! But got all glow plugs out and changed. Then started on the injectors got 4 of them changed my 5th one didn't have the copper ring on it when it came out so I'm thinking it's still in the motor. Of course it's the one in the back where I can't see down in it. So tomorrow on the way home I'm going to purchase a pick to see if it's still in there. But again they may not of installed one?? That injector looked in bad shape. I'll take a picture of it tomorrow. But so far it's been interesting.
  #64
Old 07-17-2014, 10:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
yeah more than likely it's still down in there.use a little mirror and a flashlight to get a better look.
  #65
Old 07-18-2014, 04:22 PM
SEH43's Avatar
SEH43 SEH43 is offline
SEH43 is starting off with a positive reputation.
Yesterday I got my stereo and speakers rewired and functioning properly. Also got clearance lights on cab rewired and working. I think PO was "electrically challenged".
  #66
Old 07-19-2014, 08:18 PM
3KP's Avatar
3KP 3KP is offline
What a glories day! Got my truck back to running condition. New injectors are in , New return likes, New glow plugs are in, New glow plug relay is in, And repaired my 2 broken glow plug wires. Have some thing leaking I checked all my connections and they are dry. SO something else is leaking. Guess I'll look into that tomorrow.
  #67
Old 07-19-2014, 08:35 PM
chip truck-
noticed my economy has been falling off for no real apparent reason.finally dawned on me to check my t-case even though i just flushed it not that long ago.
sure enough....burnt atf.need a t-case i guess.least i know what's going on.
funny she feels great going down the road but the economy was nose diving.has been dropping off slowly for a long while.sure hope this is the main issue.
replaced the backup cam with a higher quality cam (same monitor) the cheap one failed and flipped it's mirror image.scary like that lol.plus it was hard to backup to a trailer with it backwards.glad to have this fixed.
greased the dump bed.
back when i bought a walker big truck muffler,i noticed the thing had a vibration right from the start.something just didn't get welded right (the one in log truck is fine) and it got worse and worse.i hate...no.i loath noisy/rattly exhaust.so i just bought another muffler and changed it out (another BTM) and man that's sooo much nicer now too.all quite again.
i had a rattle of the t-case shift lever (the little pin) got bent just enough for the pin to just touch the side of the case and cause a vibration/rattle upon engine load,in OD it went away but annoying before getting up to speed.so anyway i bent that out away so no more rattle there either.
so the last few days iv been looking for oil drips.she's no longer leaving spots when parked.the punched holes in the valley cured that issue.may take another week or two for the already wet oil under there to dry up some more but that's ok.glad its stopped.
the old gal is starting to feel like new all over again.always something.there's always something.
  #68
Old 07-19-2014, 09:25 PM
Pulled the old stock torque converter and replaced it with a new Hughes low stall/low slip unit. Feels less mushy off the line and my egt seems to be a little lower while cruising. Hoping to gain a mpg or two from it.
Replaced the trans modulator valve as well. Vacuum line was full of atf so I figured it was time to replace the valve.
  #69
Old 07-19-2014, 09:40 PM
94IDIsuperduty 94IDIsuperduty is offline
94IDIsuperduty is starting off with a positive reputation.
I broke the vent window because i locked the keys in my truck.......
Tomorrow i will be fixing my vent window that some idiot broke.
  #70
Old 07-19-2014, 10:13 PM
mitchgordon96 mitchgordon96 is offline
mitchgordon96 is starting off with a positive reputation.
Found out my vacuum pumpbis shooting fuel out of it
  #71
Old 07-19-2014, 11:45 PM
that's not fuel,it's some type of lubricating oil.
  #72
Old 07-20-2014, 07:39 PM
It was fuel my buddy changed my fuel filter n accidentaly hooked a return line to my vacuum tree but now I don't have ant fuel peessure wen I try to bleed the valve on the filter
  #73
Old 07-20-2014, 08:59 PM
chip truck-
washed inside and out.vacuumed and armor all.
inspect and topped up all fluids.
tire pressure check (you can never trust tire shops lol) most needed 5-10 lbs.all up to 80 lbs.
saw instructions for new backup cam online.blue wire is for the grids on screen.so i cut it.that's nicer without those.
drivers inner fender...umm flap? (the big flap up behind the shock) was hanging.little bolt with double washer cured that quick.
replaced relay for fog lights,so those work again.
aluminum door sills.i had bought them from lmc way back but never got around to installing.those look nice.
  #74
Old 07-20-2014, 09:06 PM
you've got to hide a key on the truck just in case.
  #75
Old 07-29-2014, 06:04 PM
chip truck-
(last night)
replaced the T-case.found one with the PTO.not sure i'll have any use for it,but they claimed it had low miles at the yard.for $150 w/ 30 day warranty and it keeps me action i couldn't go wrong.
now hopefully i'll see the economy go back up where it belongs.these bw 1356 units never seem to last me much more than 100k miles.i do shift in and out of 4 lo and creep around a lot per day.i suppose i must use the t-case,often without even 4wd probably 15-20 times per day id say on average.not sure how or why that would ware 'em out but whatever.cheap and easy enough to replace though so i guess it's ok.
7.3 idi running rough + fuel filter light giorgio.fo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 02-06-2017 11:43 PM
FSV Retrofit questions FordTruckfan89 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 11-16-2015 04:05 PM
WONT PRIME AFTER IP INSTALL HELP! loganmick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-25-2015 10:12 PM
WTB IDI Fuel Selector Valve jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-28-2013 08:03 PM
Not getting fuel altruego Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 05-17-2011 05:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
