Long crank when cold. What to look for?
You could try leaving the key in the on position for around 10 seconds before attempting to start it. Another thing you may try is disconnecting the ICP sensor located on the passenger side valve cover, while you have it disconnected make note of any oil in the connector reconnect it and then start it.
good to know. I just read to try to start with the ICP disconnected. I did not try that. I just pulled the pig tail and verified not oil in the connector. I will give that a shot when it cools down again.
Its crazy that it only does it when the engine is cold. If I have ran in within the last hour or so. Then it starts up like nothing is wrong. I live in houston so cold isnt frigid temps. Just around 80 to 90 degrees.
Update as of yesterday. Not holding my breath but i changed the oil and fuel filters. I always use racor or morocraft ordered from deiselsite. I also always use rotella T6. Well it has cranked right up like nothing is wrong. I noticed the fuel filter on the frame rail was extra dark in places. I hope this was the problem. I will repost my findings after a few more days. To be sure.
Ok I have been busy but the new filters and oil did NOT fix my problem. Still takes too long to crank. I did get Auto Enginuity for my birthday. I have yet to load it on my laptop. I am going to load it soon and see what I can find. I am still leaning towards possible glow plugs. I did add a plug for my block heater. So I am going to plug it in tomorrow see if that does anything for it. I am still thinking glow plugs. No codes from my torque app but maybe the AE will find something. Thanks for all the guidence...
ok Guys UPDATE...
I have come to conclusion that the trucks cranks right up within 2 seconds everytime I park with the nose up. What would cause this? So if I am on flat ground its hit or miss. If it is nose up even just slightly it cranks right up. Even in the Mid to low 30degrees temp outside.
So to recap.
FICM volts are Great
I run Rotella T6. Oil level is on the high side of the dipstick but in range
Tried the Hair dryer on the FICM to warm it up "no difference"
I installed a fuel pressure guage and the fuel pressure is great
It only happens when the truck has been sitting for 4 plus hours
I tried plugging in the block heater. "made no difference"
I have brand new Platinum DieHard batteries
Outside temp has nothing to do with the long crank
Long crank varies from 5 to 8 seconds
Truck runs great when started. No missing, no lack of power
I have AE I have done contribution test. Everything looks great
I have not done an air pressure test. Maybe this will tell me something?
So I am guessing something is draining out of the high pressure oil system and when I park it nose up that keeps it from draining? Maybe a dummy plug? I am hoping someone else has had the same issue. I read of similiar issues being cam position sensor? Sounds far fetched in my case. I do not have any codes that pop up on AE either. Thanks
So to recap.
ok Guys UPDATE...
So to recap.
So to recap.
ok Guys UPDATE...
So to recap.
So to recap.
#28
I have monitored the pressure when cranking. I have a hard time seeing it. Seems as if it builds pressure slow then bam all of the sudden its cranked and over 500psi.
The IPR at idle is around
23% @190 degrees engine temp at 692rpms
25.9% @190 Degrees engine temp at 702rpms
I have not tried at 2500rpm. I will try that soon and see what I get. Those numbers are off my torque app. I just did some screen shots in the past.
It is just crazy to me to think that parking nose up makes it start right up. Almost seems like I am draining something in the High pressure oil
I have to look at the ICPV's I have not monitored that. Do you know if I can get that off the torque Pro app or do I need to use my AE? I do not see it on my torque Pro list.
#29
#30
I have never seen it past 500 and not started. It seems to build slow then cranks up and shoots past 500. So my guess is it fires up right at 500. I tried pulling the pig tail off the ICP sensor but it did not make a difference still slow to crank. It seems to me that its a pressure thing. But I could be wrong. I was thinking maybe my oil filter was draining into the block. but I pulled the filter the other day and it seems saturated and once I put it back in. It actually cranked right up even after the oil filter had drained out. So I dont know if that would even make much of a difference it was draining with a bad valve in there. Thanks for all the advice by the way....
