Why limited to 100 mph?
. Liability may be another reason... kill somebody going too fast and deep pockets like Ford's get sued... even if not at fault... Ford got burned good in court on the Pinto fiasco... it's a waste of time and effort to sue anybody with no money... GM was fined over $100Million for 1 exploding gas tank after juries discovered Ford had decided that $1Million jury decisions for deaths in Pintos were an acceptable risk... cheaper than re-designing/recalling Pintos... which was revealed in Ford documents by a whistleblowing engineer...
. UnSpeedRated tires only good to 92 MPH...
. Canada and USA have different regulations on what vehicles are limited to what speeds...
. My '78 F150 SuperCab 4WD full size 8' bed truck w/ snowplow is limited to 75 MPH by the weak 351M engine... the brakes are even more pathetic...
I understand and am OK with the F-150 EB being electronically limited to 100 mph. But, beyond the safety aspects, WHY has Ford done this? There must be other reasons as this truck with other engines is not limited. I've never had a vehicle with a speed limiter and I'm dying to know why. 100 mph is plenty fast but I want the REAL reasons. Heat buildup? What? What!?
Ever see a NASCAR race where a car gets airborn? Aerodynamics come into play after a certain speed. Hood pops open over 100? Sue Ford for a poorly designed latch. Ever drove one at speed and it felt like it was "floating"? Wonder how far away you were from that airborn thing I was talking about? A truck is as aerodynamic as a brick. That was a consideration NASCAR had before having truck races at Daytona and Talladega. They had to "adjust" the aero for all of them to keep them on the ground.
I wonder if the guys with the late F 150's that are supercharged and run 115+ mph in the 1/4 know about hoods popping open?
I have an 86 F150 4x4 with the 302. It's backed by a n.p. 435 4 speed. And I can easily break into triple digits with it. I just would suggest running it there for extended periods or for very often. As these engines weren't built for that purpose. I should mention it runs the 3.50 gear ratio.
#29
#30
I cant run that fast in the quarter but the SC 05 will do at least 120. I don't know how much faster thanks to the spedo. I have the ram air hood but with the inlets blocked off and has never done anything. Now I hit a deer going 80 in a Buick park avenue the hood popped open...It was scarier than hitting the deer.
Get some 10 ply tires and a good custom tune. Get going really fast in your truck...I only had to do it once, didn't care to do it again. Handling was very very sketchy.
