Why limited to 100 mph? - Page 3 - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
  #31
Old 04-19-2014, 10:19 PM
paredneck33's Avatar
paredneck33 paredneck33 is offline
paredneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to behold
Quote:
Originally Posted by BuzzLOL View Post
. An '85 truck had an 85 MPH speedo that would 'bury' easily?
The speedo reads to 85, that is true. But the needle will actually go way past that. And I know for a fact that the needle in my 78 150 4x4 will rap all the way around. I can't remember if the one in my 86 150 would do the same or not.
  #32
Old 04-20-2014, 10:37 PM
finn finn is offline
finn is gaining momentum as a positive member of FTE.finn is gaining momentum as a positive member of FTE.
Lots of speculation in this thread.
The correct answer is tire speed rating and driveshaft critical speed / harmonics.
Whipping of the driveshaft and subsequent pitching it out the bottom of the truck, and a tire blowout in a truck designed to go faster than the tire speed rating are both items an intelligent design would avoid, hence speed limited by the vehicle electronics
  #33
Old 06-07-2014, 03:55 AM
tgtrotter's Avatar
tgtrotter tgtrotter is offline
tgtrotter is starting off with a positive reputation.
Finn, then why did my '01 F250 have a limiter of 94mph but my '05 F250 would go 110mph? Never got it faster because like Raider50 posted "handling got a little sketchy"
I think the OP asked a curiously dumb question being that he already knew the answer. Love this forum !!
  #34
Old 06-07-2014, 06:29 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i think it is a safety thing. passenger and taxi crown vics are limited to 95. police package crown vics will do 137 mph. and that 137 number was confirmed by 2 different GPS units on the Connecticut turnpike back in 2005. my car and 2 Connecticut state police cars, all topped out at the rev limiter doing 137 mph.
  #35
Old 06-07-2014, 07:11 PM
What was the gear ratio, overdrive ratio, and tire speed rating of the '01 and the '05? Were they the same? Did both have the same wheelbase and driveshaft length?
Medium trucks are often limited by driveshaft harmonics, as were many rear wheel drive cars and light trucks..
There's lots to this fad of actually engineering a design.
Math is your friend.
Just checked Tire Rack: 01 had 16" and '05 had 17 or 18".
Some 01 had Q speed rating: all 17 and 18" tires are R or S rated in a cursory search.
The other issue with the EB speed limiter may have to do with converter cooling. Di engine technology may not be compatible with the strategy of richening up the mixture at high speeds to fuel cool the converters that normal gasoline engines use. (Based on discussions w/ Ford Engine Development engineers a number of years ago).
  #36
Old 08-17-2014, 06:22 PM
scott91370 scott91370 is offline
scott91370 is gaining momentum as a positive member of FTE.scott91370 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by gilchris View Post
Since I asked the question and referred to the safety aspect, safety is obviously not reason enough for me. If you don't have an answer why post?
Why not? You asked for a reason that, more than likely, does not exist.
  #37
Old 08-17-2014, 11:06 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
OP sped off after his last post on 10/3/13. This ain't even a sleeping dog--it's a dead horse.
2011 Lariat Limited Towing Numbers Limited_865 2009 - 2014 F150 5 12-20-2016 10:04 PM
2011 Ford F-150 Platinum 6.2L DougieGB 6.2L V8 8 10-08-2011 12:07 PM
Oregon... Speed Limit? or Speed Suggestion? dchamberlain Oregon Chapter 17 08-25-2011 01:05 AM
Speed limiter shuts off fuel at what speed? Wagion 1999 to 2016 Super Duty 4 05-18-2010 07:05 PM
What speed does your truck limit at? TwIsTeD OfF 6.4L Power Stroke Diesel 16 02-08-2008 06:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
