cab corners - Ford Truck Enthusiasts Forums
cab corners
Old 10-02-2013, 03:42 PM
Gregxlt's Avatar
Gregxlt Gregxlt is offline
Gregxlt is starting off with a positive reputation.
cab corners
Does anyone make foward cab corners for our trucks. I'm in need of both sides. I have searched and am coming up empty, I was almost sure I have seen some listed somewhere in the past though.
Old 10-02-2013, 04:54 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Old 10-02-2013, 05:33 PM
Gregxlt's Avatar
I already checked them sites, I'll check again but I sure didn't see forwards anywhere. They all had rears.
Old 10-02-2013, 06:05 PM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
cab corners
Greg, I think you have found correctly. I have not seen anything for the front cab sections to fit our 57-60 models, except for floor pans, and the floor reinforcement piece that goes from the floor to the step riser.
I have been looking at the 61-66 parts for that same area and I have a guy here that has a 62 and I am going to get with him to make some templates to see if the later model pieces will fit, or can be modified to fit our trucks. I need some of that metal too for my 57 and it would, might. be helpful, if not too expensive, to have stamped pieces we can use.
I will post my findings when I get together with that guy and do measurements, pictures and templates.
Hope this is helpful.
Aloha, Tony
Old 10-02-2013, 06:13 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Greg if you are talking about the boxed in area just below the lower hinge. I looked also and ended up making my own, it was not too hard but then again my don't look original. Should be pictures in my albums. If you can weld in store bought panels you won't have trouble building these parts. Look at it as a chance build your skills.LOL
Good luck in your quest!
Old 10-02-2013, 06:49 PM
Gregxlt's Avatar
Thanks everyone! Lode brush keep us posted, very interested! Teddy I'll check your album out. I'm not too concerned about them looking original, you can't really see them anyway.
1948 - 52 Cab corners reamer Ford Truck Parts for Sale 14 06-25-2016 07:56 PM
Cab corner question Mixer man 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-27-2015 09:05 PM
Cab corner quesition whalebus2112 1987 - 1996 F150 & Larger F-Series Trucks 5 06-07-2014 09:19 PM
Supercab cab corners kadrocker 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-29-2014 07:06 PM
Glue on Cab Corners megawatt00 Paint & Bodywork 14 02-16-2014 08:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
