7.8 smokes on start up - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 10-02-2013, 12:58 PM
Rlawmulching Rlawmulching is offline
Rlawmulching is starting off with a positive reputation.
so, as I mentioned in a previous thread, i'm working on my 1989 f800. when the truck first starts up when cold, it smokes for about 20 minutes then clears up. no loss of power. any ideas?
Old 10-02-2013, 11:59 PM
nevrenufhp's Avatar
nevrenufhp nevrenufhp is offline
nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.nevrenufhp has a good reputation on FTE.
That is very common with the 6.6 and 7.8 engines. You can double check the timing, and fuel pressure, but I've seen quite a few do that and run fine for many years.
Old 10-03-2013, 10:26 AM
could the turbo be leaking a little after sitting over night? I've seen that happen on logging equipment. also, where can I pull a boost gauge off of this system?
Old 10-03-2013, 10:41 AM
nevrenufhp's Avatar
It is possible, yes.
There should be a couple fittings on the intake manifold you can use. The intake is dry, so any port will be air.
Old 10-03-2013, 11:08 PM
Pete Kildow Pete Kildow is offline
Pete Kildow is starting off with a positive reputation.
Mine is clean burning on startup. And only shows fuel smoke when getting on it. And need to turn the smoke screw back on it to cut part of that out. As it leaves 2 trails of smoke at every shift or when pulling. Will blow smoke 30ft behind me under a load.
Is yours fuel smoke or oil smoke? Wondering if you have something leaking oil down into the motor and taking a while to burn it off? Or fuel and having to burn it off?
Old 10-09-2013, 03:46 PM
rogue40's Avatar
rogue40 rogue40 is offline
rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.rogue40 has a great reputation on FTE.
I can't find if the glow plugs go through a warm up cycle like they do with the pickups to eliminate fuel smoke after startup.
Do they?
Old 10-09-2013, 04:32 PM
Quote:
Do they?
No glow plugs on these. Just starts more like a gas motor.
Pete
1997 F-250, 7.3 Thick white smoke a start-up Mercniac 1994.5 - 1997 7.3L Power Stroke Diesel 19 11-21-2015 02:05 PM
white smoke on start up i eat hybrids 6.0L Power Stroke Diesel 2 07-28-2010 12:19 PM
Help..ALOT of smoke. Powerstroke-7.3 1999 - 2003 7.3L Power Stroke Diesel 20 12-09-2009 11:17 AM
blue smoke at easy cruise stresscrack Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-03-2009 09:48 PM
white smoke from tail pipe weldingfreak 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 02-12-2006 04:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
