LED light bar pics
Rigid Industries has pictures of their setups on their website. Although this says it is for a 2011-2013 it looks awesome and would be where I would mount one if I did not have a replacement front end. You could custom mount one in the same area and achieve the same look. Just my opinion. (The bracket may even fit, but I am unsure.)
https://www.rigidindustries.com/category-s/135.htm
For my experiences the current market of LED bars leaves you wanting more for your money. My research found most bars are using 3w LEDs. My KC 6x9 HIDs will outshine the 30" LED bar. The LED bar is great for about 200' and side-to-side is improved. The KC HIDs will easily tag 300'+ with good side-to-side coverage. My LED bar was $250...if you spend more you better be sure you are getting better than 3w per LED.
The mounting bar I am using is from a company out of AL I recall. They are on Ebay if you are interested. The LED light bar is from M4Products.
Good to know. Thanks for the info. I don't want to be passing out bad info/products. Just out of curiosity, what mounts are you using that are more sturdy/theft proof?
Gage
As far as led light bars "not meeting expectations" this may be the case with a cheap bar. $250 (not to single you out) isn't going to get you a great bar.
To get the best light output get a combo spot flood, and make sure it uses CREE LEDs. If price is more important there are cheaper options than CREE, but they produce the most light.
