Throttle bucking
Old 10-01-2013, 07:46 PM
cory5517's Avatar
cory5517
cory5517 is offline
Throttle bucking
Just bought a 04 f150 5.4. When accelerating to go up a hill the truck will buck or shudder till you throttle through it. Any ideas?
Old 10-01-2013, 07:47 PM
cory5517's Avatar
cory5517
cory5517 is offline
Like the transmission doesn't know what gear it wants to be in
Old 10-01-2013, 08:37 PM
danorules's Avatar
danorules
danorules is offline
Any codes ?
Old 10-01-2013, 08:45 PM
cory5517's Avatar
cory5517
cory5517 is offline
No engine light but that doesn't mean the previous owner didn't turn off the engine light. Will go see if there's any stored codes tomorrow
Old 10-01-2013, 08:57 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
sounds like a miss fire to me . Ck for codes , pending codes , and mode 6 . Cyl cont. test would be helpful if you can . Look at fuel trims , long and short, if nothing else . That can lead you to the offending bank . Just a thought !
Old 10-01-2013, 09:12 PM
cory5517's Avatar
cory5517
cory5517 is offline
We'll after doing some researching the ticking I'm getting after engine warms up could be cam phasers. What and where are the cam phasers lol?
Old 10-03-2013, 10:48 PM
ThirstyFX4's Avatar
ThirstyFX4
ThirstyFX4 is offline
Sounds like a misfire. It's probably time to replace the sparkplugs.
Old 10-04-2013, 06:40 AM
cory5517's Avatar
cory5517
cory5517 is offline
Went and had codes read and came up with a 2&3 misfire but was told it needed a valve job. Taking it in to have valves done then gonna get plug and coil pack tuneup
Old 10-04-2013, 07:18 AM
ThirstyFX4's Avatar
ThirstyFX4
Good luck with that.
Old 10-04-2013, 07:36 AM
cory5517's Avatar
cory5517
cory5517 is offline
Truck has warranty thank god
Old 10-04-2013, 09:45 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
If none of the above posted solves it, it might also be a bad TPS throttle position sensor.
Old 10-04-2013, 09:49 AM
cory5517's Avatar
cory5517
cory5517 is offline
Can't you test a tps by using the cruise control?
Old 10-04-2013, 10:43 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
That makes no sense ! Smells fishy to me !
Old 10-05-2013, 08:08 AM
cory5517's Avatar
cory5517
cory5517 is offline
The valve job part?
Old 10-05-2013, 08:09 AM
cory5517's Avatar
cory5517
cory5517 is offline
I think it needs a coil and plug tuneup and cam phasers
Quick Reply: Throttle bucking
