October Spooky Virginia Chat
#110
Nope. Only way to bring it back out is with an adjustable upper control arm...which is over $200. Camber on a MacPherson strut is real cheap and easy- aftermarket cam bolts. Not that cheap on this setup. Curious if something was run over, since camber on both right wheels is out. Lower control arm is plastic and pretty scratched up, so it could have been stretched somehow.
#111
Devin, welcome to the world of wacky specs. A lot of "specs" cover a large range. You know it's wrong but "within specs - so it's ok" . Some machines are set up for the mfr. specs so if it's "in the green", it's ok.
Morning Virginia.
Enjoy the fishing, Rocco.
Morning Virginia.
#115
Looks good Devin. I have several pairs of Red Wing boots and shoes. I love them and they are still repairable depending on the sole by my local shoe repair guy. If he cant fix them then Red Wing can fix them. Which model boot did you get?
#117
I have 2 pairs of the 3507's. 2 pairs of the 8220's, 1 pair of the 4408's, 1 pair of 133 which is the 4408 with out the steel toe and 1 pair of the 6690's. Sadly they dont make the 8220's anymore.
#119
That I have Devin. My one pair of 8220's has already resoled once. Even managed to snag a zipper kit for my other pair of 8220's. Makes it so I just zip into them instead of lacing them up. Got the zipper kit for free.
#120
Dang that looks fun!
I'm a tad pissed at Honda. Did an alignment on the Civic today. Toe was out on the front, so I got that straightened out and got the rears set dead on as well. Check out the camber on the right-rear, though. Non-adjustable It's "in spec", but it's gonna cause wear issues
