? on doing dash repair on 50 F1
Hi all, with winter coming up I've been pondering welding in a clean radio patch piece, that I was happy to get from a fellow FTE member a while back. My question is , is it better to do a butt or flange weld after trimming to fit? Any suggestions would be greatly appreciated, since I'm not the most experienced welder. Thank you all.
Jimmy, I will agree with Ilya. Go with butt welding. Leave a little space (1/32" or so) between the patch and the dash metal, weld real short stitches and let them cool. Watch for warpage all the time. Leaving that space will let your weld metal flow onto both parts, giving you a stronger weld. It also will allow enough weld metal to fill so your grinding will not remove too much strength. If you have it, use a good Argon mix gas (80% argon-20% CO2, or 98% argon-2% O2, or such) rather that straight CO2. Maybe AX will confirm or correct, let's see.
Some progress pictures will be nice.
Aloha, Tony
Aloha, Tony
Butt Welds! Use the copper backing plates whenever you can and just go nice and slow. Better to jump around and come back to the project than to rush it and get it too hot and warp it. My problem is once its welded, I grind the welds down too far and they when I go back to fill the pin holes, its like tin foil. Not good. It took a lot of practice to avoid this. Careful with that grinder on a butt weld.
Suffolkman
01-15-2022 03:51 PM
3twinridges
11-27-2016 12:28 PM
KOMBILOVE
07-23-2011 11:23 PM
sancochojoe
17
04-14-2004 04:43 PM
