New Garage/Shop
#481
#484
#486
That is not what Bill did. He balanced his lighting with 1/2 of it on the A side and 1/2 on the B side.
Anyway, if you start moving things around be aware that you need to keep the load balanced. Otherwise your A and B voltages can be quite different and any 240v devices you have may not like it.
#487
I finally had a stretch of decent weather to throw some paint on the wood to protect it. This is a first coat of latex primer done with a Ryobi airless sprayer loaned to me (thanks Matt!). I think I will probably want to put a second coat on as there are some areas that need a better coat. Once that is satisfactory I have a final coat that is as good a match as Lowe's could give me to the house siding.
This will at least protect everything until a week or so can be coordinated to get the Tyvek and siding up.
#492
#493
Jim, I have paint colored to be a close match to the siding on the house that will go on after the primer. Probably later this year Matt will be coming down to help install siding on the garage front. It is a combination of protect the plywood and make it look a little better for now.
Last edited by 85lebaront2; 05-10-2015 at 06:31 AM. Reason: Added words to clarify.
#494
I think your garage looks great!
What I'm saying is that good paint has enough pigment to hold out, where primer is meant to soak in and doesn't necessarily hide 100%.
2 primer & 1 topcoat will not give the results of 1 primer and 2 top coats, although the labor is the same.
If you're going to power wash your doors, you probably want to do that before finish paint.
