Update on the doors, we got them off the trailer this morning and did a quick measurement. They are apparently custom, one is 11' 8" the other is 12' 6" in width. Height is currently unknown until I get a chance to sort the track pieces.
Both on the North (front) wall, it was always planned to have two garage doors and one walk-in. It will be nearer the center so it will provide good access to the lift once it is installed.
Reason: Further line.
Due to the door dimensions, and the fact that the lift pads were poured with the floor, it will not be exactly in line. My lift will not be the drive-on type that you have, mine will be a frame lift so I can do brake and suspension work on it.
Mine isn't drive-on. I originally thought I wanted one of those, but am 125% sure that would have been a big mistake given the amount of suspension and brake work I've done. Not to mention trying to get a tranny under the ramp.
After talking to Kyle's (first today's) friend and doing some further digging I found the operators are Overhead Door Model L units, the numbers stamped on them would have been the order number. After some measurements, I found they are even bigger than Donnie thought, one is 11' 8" wide and the other 12' 6" wide, height appears to be around 14' 6". Openings were probably 11' 6" X 14' 6" and 12' 4" X 14' 6". I will be shortening the height of one or both.
Now I need to find some structural requirements for the wall, the angles that attach them are 3 1/2 X 3 X 1/4, currently 16' 7" long or high depending on whether they are on the ground or attached to a wall.
