CLUTCH MASTER AND SLAVE - Ford Truck Enthusiasts Forums
International Region Australia
Old 09-30-2013, 11:28 AM
MRPERSONALITY MRPERSONALITY is offline
MRPERSONALITY is starting off with a positive reputation.
Heya guys, need some help on this one form south Africa here and nearly complete to finish my rebuild on my F250 and now I wanted to replace clutch and slave units while im busy and behold our Ford dealer informs me that they no longer keep these units, so could anyone help me as I see afew in ebay. its the 4.2l unit
Old 09-30-2013, 01:39 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
The 4.2 uses the ZF5 (essentially the manual transmission behind older F-Trucks that were sold in the US up to 1997).
I would guess that their master/slave would be the same, but could be entirely wrong.
Here are some example parts off older F-Trucks in the US:
More Information for DORMAN CC649005
More Information for RHINOPAC / WORLD CAR PS0713
Do they look similar to yours?
Here is one for a similar year to your 7.3 (fitted with the ZF-6, different trans)
More Information for RHINOPAC / WORLD CAR PS0722
The only thing that in my mind wouldn't match up is the hydraulic line, but you should be able to reuse your existing one.
Also, bear in mind that this is free advice from someone that hasn't looked at a 4.2l F-truck for almost 10 years. Take it for what it is worth
Old 10-03-2013, 09:43 AM
THANKS a lot really really appreciate it, heres some pic maybe you can make more sense of it, I just wanna buy master and slave to have as a spare
Old 10-03-2013, 10:26 AM
For some reason the photos didn't load?
Old 10-03-2013, 10:47 AM
Old 10-03-2013, 01:40 PM
They are all pictures of the slave cylinder, correct?
Do you have pics of the master cylinder?
Old 10-03-2013, 03:10 PM
Unfortunately the photos you have taken don't really help in identifying what master/slave kit is fitted to your truck.
All you need to know is if your master cylinder has the overflow reservoir attached directly to it (old style that I linked), or if it is mounted separately on the firewall (same style as the newer 7.3 trucks with the ZF6).
If the reservoir on the master cylinder is a part of housing, find a pre 97 master/slave assembly for 7.3l US truck. If the reservoir is separate, find a 2000+ master/slave assembly for a 7.3l US truck.
I find (site sponsor) RockAuto Parts Catalog a good place to find parts.
Old 10-03-2013, 03:23 PM
The overflow reservoir is separate on the firewall and has pipe attached to the top part of the master.
Old 10-03-2013, 03:57 PM
Old 10-04-2013, 12:01 AM
Fantastic thanks again for your help. going to order now
Clutch aND slave cylinder help newguy399 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-12-2016 11:59 AM
'86 T-19 Clutch Fork & Slave Questions mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 04-03-2014 07:55 PM
clutch slave cylinder removal Dre82s 1987 - 1996 F150 & Larger F-Series Trucks 14 11-11-2010 08:23 PM
NEED CLUTCH SLAVE CYLINDER HELP 88 250 colesdad 1987 - 1996 F150 & Larger F-Series Trucks 3 05-02-2010 06:51 AM
Luk Replacement Clutches and Slave Cylinders thanksbutnothanks Ranger & B-Series 8 01-03-2007 03:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
