Removing CAB from Frame?
Still trying to figure out if I wanna go one piece on the side glass. I believe in the long run it may be cheaper and I never remember opening the vents but defiantly remember the screeching they use to make when they didn't seat properly. I will have A/C in the Panel!!!
I have done it both ways, but when I left it in I always ended up removing it sooner or later. If you are careful removing the cab, the glass is not going to break if left installed. If your cab is moving enough to crack the glass, you are going to have serious issues getting the cab to line up with the front sheet metal, doors, and the cab mounts when you put it back in.
Hi you all and thanks for the feedback
Just a short explanation:
I have planned to restore the chassie and driveline in first hand and depending on how long time (and money) it takes. And also how feed up I feel when chassie and driveline is ready (how big the urge is for driving) I just might throw the old body (as is) back on and enjoy it for driving a while, before attacking the body.
That one of the big reasons I dont want to remove the glass from the CAB.
I have two small kids (1 year and 4 years) so I imagine the chassie and drivetrain end date is highley dependable on these small angels and the moneything of course.
If the truck you are working on is the green one in your signature, that's a really nice truck already! Why take the cab off? that's an awful lot of work just to reach 4 foot of frame top for a truck you plan on driving rather than just showing. There is very little under the cab you can't get to with the cab in place. I'd recommend leaving the cab on the frame, restore your driveline with it in place. It will save a lot of time towards getting it back on the road. Later on if you want, take the cab off and paint that small amount of frame top.
If the truck you are working on is the green one in your signature, that's a really nice truck already! Why take the cab off? that's an awful lot of work just to reach 4 foot of frame top for a truck you plan on driving rather than just showing. There is very little under the cab you can't get to with the cab in place. I'd recommend leaving the cab on the frame, restore your driveline with it in place. It will save a lot of time towards getting it back on the road. Later on if you want to work on the cab off the truck, take the cab off and then paint that small amount of frame top.
dmccorkle911
03-11-2014 11:00 PM
73f250400
03-01-2010 05:51 PM
