ring and pinion changes questions
Looking at doing a ring and pinion change, have noticed several comments about reverse cut gears in regards to the 8.8 front diff.
Summit offers a ring and pinion clutch type LSD combo pack that they claim fits the front axel but it says standard cut. any ideas?
This probably isn't going to help any, but all reverse cut gears I have ever seen have been for the front axle. Like dana 44 was used both as a rear AND front diff. The rear diff would have standard/regular cut gears while the front diff would use reverse cut gears.
I would just give them a call and verify that the gears you are looking at are indeed intended for a front diff
Trav460
08-11-2007 05:32 PM
Skandocious
18
07-30-2007 07:47 AM
LilDuke
12-29-2004 12:01 PM
1990F2504X4
01-23-2004 04:43 PM
shotgun
02-20-2003 09:55 PM
