04 Power Steering Issue
I bought an 04 F150 SCrew 5.4 3V a while back. The power steering fluid level keeps dropping. I have topped off the power steering resivour at least 3 times in the last month and a half.
What's got me baffled is I can't find evidence of a leak anywhere. The hoses, the pump, or on the belt. I've crawled over & under it. I can't find anything anywhere.
Anybody got a suggestion?
On my vehicles with fluid power steering, I use a vacuum canister to remove the fluid from the reservoir, then I refill with new fluid. Maybe once a year on the newer ones and more often on the older ones. This helps the system to last longer without leaks or corrosion. This method doesn't change all the fluid at once, but accomplishes the change as it is repeated over time.
Sooper Camper
12-15-2014 07:34 PM
1992FordF150Custom
07-06-2014 03:31 PM
crashed13
21
10-03-2005 03:56 PM
Bob Crain
05-19-2005 04:59 PM
