98 F150 4.6 4x4 no power - Ford Truck Enthusiasts Forums
Old 09-29-2013, 04:55 PM
redrock233 redrock233 is offline
redrock233 is starting off with a positive reputation.
My 4x4 will not engage there is no power at the on the fly shift switch. So I was wondering where it gets its power from have checked all fuses and vacuum lines wires and all any and all info will be greatfully accepted thank you all.
I have read through most if not all post that I can find and nothing
Old 09-29-2013, 05:53 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Well it's not that simple.
The switch signals a module called a GEM.
The Gem operates a transfer case motor that moves a shift control shaft and electrical connections to the first position.
This operates a vacuum solenoid on the fire wall to apply vacuum to the front axle actuator.
When these actions are complete the Gem lights the dash 4H lamp.
If the case motor does not operate it is a Fuse, the motor, or the GEM module.
The dash switch seldom ever goes faulty.
Good luck.
Old 09-29-2013, 06:19 PM
Good luck.
Ok so it just might me the GEM everything else has power or moves freely.
94 f150 no power to fuel pump loggerlife15 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 01-12-2016 09:57 AM
2000 F-150 4x4 / no power on vacuum valves Barkmarker 1997 - 2003 F150 0 06-18-2014 12:56 PM
1979 f-250 4x4 horn system okie#1 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-08-2013 08:27 PM
More Power cw974x4 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 0 10-22-2012 06:31 AM
2002 ford ranger 4x4 mattcomparato Ranger & B-Series 2 12-16-2009 06:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
