Kerosene - Ford Truck Enthusiasts Forums
Kerosene
Old 09-29-2013, 01:51 PM
ke6zmy's Avatar
ke6zmy ke6zmy is offline
ke6zmy is gaining momentum as a positive member of FTE.
Kerosene
This is probably not the correct location to ask this. If anyone knows where to do so I am glad to move this thread there.
I have a son in England who recently bought a 2000 or 2001 Ford Transit w/ a small, 2. something diesel engine.
He asked me about running straight kerosene as fuel.
What do you folks think?
Old 09-29-2013, 01:56 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
In a word, NO! Pure kerosene has almost no lubricity and will destroy his engine. He could do some mixing, but that's taking a big chance........
Old 10-01-2013, 01:32 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
they run #1 fuel most all year in Montana with out lubricity related problems, all #1 kerosene meant for motor fuel has the same lubricity modifier as #2 diesel, just gells at a much lower themp. all newer diesels have pumps and injectors designed for ULSD. the only problem would be if the fuel was kerosene for jet fuel, witch is not really kerosene, jet A and JetA1(winter fuel) are not to be confused, with kerosene Jet A is low in btu as compared to #2, however it lights easier at altitude, if it is motor fuel it is fine, less power, starts easier in the cold.
Old 02-23-2016, 08:54 PM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
he would have to add 3% to 5% bio fuel to the kerosene (clean veg oil, corn oil, etc.)
Old 04-14-2016, 01:11 AM
All kerosene sold in the US as a heating oil (called stove oil) is dyed, and has the same lubricity as diesel ULSD #1 and#2, diesel # 1 is not kerosene but its very very similar. diesel #1 and #2 is sold dyed and undyed. diesel #1 is hard to find in Washington state for sale for as ON road use..however we haul it to northern BC and Montana in winter, for ON road and dyed #1 for tractors and construction equipment in the north. BP is the largest manufacturer of Jet fuel in the north west. you cant even pick up Gas at there Rack in Ferndale WA as it all go's down a pipeline to be mixed with alcohol in Seattle (AM/PM) gas. moter oil is not approved as a engine fuel.. but will combust in a diesel engine. zinc and other additives are not fully burned and could lead to a build up on valves and pistons if burned in high consternations in a moter vehical, Diesel #6 is (bunker oil) burned in ships out at sea, when 36 miles or closer they must burn a ligher oil or diesel #2 for EPA reasons, Atf is mineral oil its a more refined oil with some chemistry changed to meet hydraulic and very specific lubricity property's, to work with band type clutches, it just so happens that it to, can be combusted in a diesel engine. cetane of diesel is the inverse of octane, lower cetane is better in diesel, higher octane is better in gas, oil burns a little slower but would not necessarily test lower in cetane. synthetic oil burns just as good as Dino oil, just costs more..no moter oil is produced at any of the refinery's in WA state. they make most of that in Texas
Old 05-12-2016, 06:56 PM
Dakster's Avatar
Dakster Dakster is online now
Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.
#1 diesel/kero is common up here in Alaska as a motor fuel in the winter.
Home Heating Fuel/Kerosene/Diesel is not guaranteed to be ULSD. Big stickers warning about running it in a 2007 or newer vehicle on those pumps. Some folks could legally run it, since there is a lot of places that are not on the road system here that you can drive on. It is also non-dyed as some areas get so cold that the dyed fuel causes problems.
The cost difference isn't that great, since AK has no road taxes, so before the people start saying you could get cheaper fuel and cheat.... It isn't that much cheaper and it isn't gauranteed to be ULSD. Just Low Sulfur Fuel.
Old 05-12-2016, 07:17 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Is the warning here applicable only to the modern hipster Diesels? It was my understanding that Kero is good stuff and should burn well in old school rigs. Or maybe a Volvo or something.
When I was in the .mil there were still a very few multi-fuel Deuce and a halfs in the motor pool, that would run on gasoline or diesel, and combinations thereof. Some of the guys would always pour a can or two of ATF into their 5 tons fuel tank for a little extra somethin' somethin'. Claimed that it was clearly visible under night vision goggles coming from the stacks which trucks did this. Hm.
Old 05-12-2016, 08:08 PM
Dakster's Avatar
Right only to the DPF equipped trucks.
Recommendations parts cleaning solvent ? JRS2 1987 - 1996 F150 & Larger F-Series Trucks 13 02-02-2016 11:08 AM
A Couple More Cold Weather Questions Flame Out 1999 - 2003 7.3L Power Stroke Diesel 6 01-20-2016 01:21 PM
Alternative fuel question Jaime74656 Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 11-10-2015 01:08 AM
Kerosene Mix Question onug 6.7L Power Stroke Diesel 3 02-23-2012 07:42 PM
bio in kerosene heater? vancouverpower Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 11-24-2005 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
