E4OD stalls - Ford Truck Enthusiasts Forums
E4OD stalls
Old 09-29-2013, 01:34 PM
Cowboydesperado Cowboydesperado is offline
Cowboydesperado is starting off with a positive reputation.
E4OD stalls
I have a 1991 F-150 302 and I have just rebuilt the transmission and she runs fine except for a wierd thing it does. If I put the trans in reverse with my foot on the brake it dies. If I put it in reverse with no brake applied it runs fine. Also tried this with the rearend off the ground. Same results and if I try to apply the brake to slow the wheels it will choke and studder until it dies. I can slowly push brake and make it studder then let off and it goes bake to running normal. Fluid level is fine. All this happens once it gets up to temp. Doesn't happen cold at first start up. Will do it in drive once you run down the road a bit sometimes when stopping for a light or something. Only stalls when brake is applied putting a load on the trandsmiision like the converter is locked up when shouldn't be. It is a new converter. Checked codes coming from trans and got no codes. Read somewhere fluid could be leaking across a gasket somewhere engaging the converter. Anybody know what gasket....valve body or pump? Any ideas?
'96 F350 transmission troubles, pressure readings inside kendogg Clutch, Transmission, Differential, Axle & Transfer Case 6 12-27-2016 07:05 PM
No power, studders and white smokey exhaust when warm F33lmywrath 6.0L Power Stroke Diesel 25 04-01-2016 08:17 PM
1999 Ford Van E250 3/4 2WD - Stalling, and I think it is because of the wrong Trans Filter kylechamb 1968-2013 Full Size Vans 4 02-04-2016 09:15 PM
Stalling in first dstraw 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-26-2015 12:53 PM
Jerking/Studder Confusion mblanken881 6.0L Power Stroke Diesel 43 01-17-2012 10:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
