H&S tunner? Y does the tranny program SUCK!!!
So as you can tell I hate the tranny program. Y does suck so bad? No matter what shift program I chose it holds out of over drive way to long, and when I let off the go peddle the tourqconverter comes out of lock up and as I'm still doing 45 in 4th the motor just idles and will not go into decel mode. So consequently when I hit the gas again the motor free revs till it catches up to the truck speed and grabs the gear really hard.
Is it just me or has any one else noticed this?
Did you just delete, reload the tune and pass on changing the transmission tune, get used to the truck as it is for a while. Retune at a later date and play with the different shift points you can use. You won't find a perfect shift sequence but you might find one that suites your fancy. First learn your new truck.
i guess i have not experienced that but possibly when it was in the tranny relearn stage? id say try running it that way for a hundred miles or so i think that's what it takes to relearn? before changing back to stock.... i know they say the tow/haul settings are whats set from factory as they are good but cant handle the higher hp tunes and recommend to be used on no power
Iv got well over 3000 miles on since I tuned it and it has not changed. as for tow haul I have another thread going bc my tow haul does not work lol
Read and follow directions!
Read then follow the directions from H&S to relearn the transmission. It works. If it does not you might have a different problem not the tune. If there is a problem with the tune H&S is very good about helping out. AS I said read the directions. Also get on H&S form and ask your questions there. Their employee's are on there.
bogginf350
08-09-2005 06:44 AM
