2006 f250 charging problem
Hi i have a problem with my f250, i bought 2 new batteries and check the alternator and its fine but i notice it wasnt charging, i dont know whats happening, only charges 12.5v instead of 13.5 or 14v, does the f250 have any alternator fuse? i cant find it please help!!!
Welcome to FTE.
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Repost the problem and you will find a lot of help.
How are you checking the voltage?
Did you take the alternator in for testing or ?
Sean
Sean
does it work when you initially start her up, but then slowly dies off?
I had an issue maybe 4 days ago with my alt. worked great in the morning at initial startup, but after maybe 5 miles voltage dropped to 12-12.5 (ie: battery voltage).
had to take in for testing while burning hot before it would "fail" the test at Oreilleys. $218 later and I have a lifetime warrantied alt...and a new battery because it killed the old suspect one that was previously there. get it fixed soon before it kills your new batteries.
not to mention that your FICM HATES low voltage and it can kill the FICM and injectors
The bad thing about the most of the newer machines in the
parts stores is that they are computer operated test and don't
take temp into account when doing a test.
So if you have a unit that is suffering from heat it can test as good.
Some times a diode will test good when cold and as it heats up the junction
will short and pass AC ripple into the DC side.
Here is a little test you can do in the truck
ALTERNATOR - Ripple Voltage Test
Using a DMM
The Alternator produces AC voltage and current. The battery requires DC voltage and current to charge properly. Diodes located within the alternator change (rectify) the AC to DC. However, a small amount of AC can still be present and no harm is done. Problems can develop when alternator diode faults permit unacceptable amounts of AC to pass into the vehicle electrical system.
1. Set the meter to read “AC” Volts (lowest range) .
2. Connect the black COM lead probe tip to the battery negative post.
3. Connect the red Volts lead probe tip to the battery positive post.
4. Run the engine at 1500 RPM.
5. Turn ON the high blower and high beam lights.
6. Your meter reading should not exceed .09 volts (90 mV) AC.
High ripple voltage readings imply faulty diode(s) which can cause:
· Undercharged battery.
· Stalling.
· Rough idle.
NOTE: If your meter reading exceeds 90 mV AC, use an ADL7100 labscope or equivalent to verify that ripple voltage spikes do not exceed one volt peak to peak.
You can find this info at Test - Ripple
There is some more info on that page.
Sean
Using a DMM
· Stalling.
· Rough idle.
Sean
jonnygorgo
29
03-12-2014 06:36 PM
cato47
08-03-2006 11:19 PM
