356,536 miles,Just was neat to see.
Was at Richie brothers today and saw this 03 F-350.It had 356,536 miles on it.was in pretty good shape to.Had a 12/03 build date.It started right up with no problem and sounded just like my 07 with 44,000.I have no idea of the history of the truck or what it took to get it there,but I will say that it did have green coolant in it and an aftermarket oil filter .
My lifters needed attention at 582k tho. Causing a total rebuild. I'm planning on 500k, pulling the engine n replacing the lifters as preemptive maint. Can't wait to see other 6l's get high mileage. I worked my truck, but was meticulous with maint. I also had 10, of the 16 lifters bad. Which points toward their total lifespan.
The problem is that you have to pull the engine or get access so
the back side to remove the branch tubes to pull the last set of lifters.
The local shop that does a lot of 6.0Ls said that he as a rule will replace the back set
anytime he can get to the back half of the engine without costing a bunch of money.
One of the Ford mechanics said some thing about the back lifters being the ones that
tend to be the ones that fail the most.
Can some verify that statement?
Anthony did you find any pattern to the failed lifters?
I would like to see if the lifters could last longer with more oil. But that will be hard
to do on two fronts. You have to get the oil back there and then you have to test to
see if the work to get oil to the back lifters does any good.
Sean
Sean
starrs
12-05-2010 06:42 PM
Beachbumcook
11-10-2008 09:57 AM
1987_f150
General Automotive Discussion
13
05-16-2005 09:48 PM
