spiking gas with alcohol. help emmisions? - Ford Truck Enthusiasts Forums
Old 09-28-2013, 07:00 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
does spiking the gas with 99% alcohol really help with emissions?
I heard to put about a gallon of alcohol in 6 gallons of premium gas will make an engine blow clean on an emissions sniffer.
can anyone call this fact? or BS?
Old 09-28-2013, 11:01 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Maybe. Have you attempted to smog something and failed? If so, do you have a print out of your results?
Alcohol could have negative effects on fuel system components also. Especially methanol.
Old 09-29-2013, 01:39 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Actually, methanol...up to a 10% mix will reduce HC, NOx & CO.
Old 09-29-2013, 05:58 PM
yes I have tried to smog something and failed on HC's...
my neighbor runs his stock car on alcohol, im gonna ask him if I can have a gallon....
Help make my truck run bad 68F250"GERTIE" 1967 - 1972 F-100 & Larger F-Series Trucks 35 02-26-2015 02:48 PM
Alcohol Injection Systems 91 Dually 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-30-2013 11:58 PM
rubbing alcohol in gas tank daddy172005 Fuel Injection, Carburetion & Fuel System 15 07-03-2008 11:40 AM
rubbing alcohol will help pass E-check? rtbstrd Ford Inline Six, 200, 250, 4.9L / 300 17 01-13-2006 02:24 PM
Any tips for passing smog check? tigerdude2001 1987 - 1996 F150 & Larger F-Series Trucks 6 12-11-2001 12:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
