Help with '99 F150 instrument cluster
I was reassembling my cluster after a cold solder joint fix and this piece fell out.
It's gray rubber about 1/4" in diameter and 1/4" high. Some sort of spacer I think.
Does anyone know where it goes? I looked at it for half an hour and I just can't see where it fits. Looks too important to leave out.
Found it! I pulled the cluster apart one more time and looked inside just as I separated it and realized it goes on the end of the select/reset button. The rubber piece fits into it and the other end creates just a bit of suction when it is pressed activating the chip that controls the select/reset function.
Back together and odometer works like a champ now.
