460 Bellhousings - Ford Truck Enthusiasts Forums
460 Bellhousings
Old 09-28-2013, 02:33 PM
rattrucker rattrucker is offline
rattrucker is starting off with a positive reputation.
460 Bellhousings
I am putting a 1970 Lincoln 365 horse 460 in my 1950 Ford F350. I bought a Bellhousing from a man that said it was a rare 1979 460 bellhousing #D9TA-1505-BA. Is this a 460 or 400M Bellhousing?? I need to know this to order a 460 Flywheel or go the 390 Flywheel for the 400M. its a steel Bellhousing and the clutch arm pivot is different than a 400m, its aluminum not steel
Old 09-29-2013, 11:48 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Sounds like a later model bell housing that would have used the hydraulic clutch linkage.
460 AUTO to NP435 swap questions ManfredVonRichtofen 1978 - 1996 Big Bronco 1 01-08-2014 10:50 AM
460 with 400 bellhousing- what starter to use? F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-18-2013 02:50 PM
460 hydraulic bellhousing w/ mechanical linkage? bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-28-2012 02:39 PM
Will a 390 flywheel fit a pre-79 460? Catman 24 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-15-2011 05:30 AM
Bellhousing, clutch for a 460 and t-18 tranny bigdan1979f-250 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-26-2009 09:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
