MAP sensor - broken - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
MAP sensor - broken
Old 09-28-2013, 06:00 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
MAP sensor - broken
I knocked the MAP sensor with the IC tube and broke the pressure intake off. On removal I noticed that it has been broken before and stuck together with silicon.
Any recommendations of where to get a replacement?
Is there any issue with running without it? I plugged up the hose. CEL is not on - the body of the old map is in the toolbox,
Old 09-28-2013, 07:20 AM
Picked one up at RockAuto.com
https://www.rockauto.com/catalog/moreinfo.php?pk=607433
AUD$125 including Fedex express
Map Pocket Trim Ring AubreyA3 1961 - 1966 F-100 & Larger F-Series Trucks 10 08-16-2016 08:38 PM
EBP and Map locations KDAVID1 6.0L Power Stroke Diesel 4 11-14-2014 03:23 PM
Compare Baro,EBP,MAP on TorquePro Cell's 1999 - 2003 7.3L Power Stroke Diesel 4 10-02-2014 04:43 PM
Map sensor location v10 ? Jnowaczyk Modular V10 (6.8l) 2 11-05-2013 03:55 AM
MAP Sensor voltage ??? pjnadon 6.0L Power Stroke Diesel 3 01-22-2011 11:01 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
