1975 F250 Driveshaft too short?
Old 09-27-2013, 07:11 PM
1975FordF250's Avatar
1975FordF250
1975FordF250 is offline
We have a 1975 F-250 RWD Auto with 390. I was going through everything when I noticed the rear section of the driveshaft (past the carrier/center bearing, rear end side) where it slides on it seems to not be on the spines all the way. I can push it up and down like it's barely on the splines. I don't know if this is normal and that is just play, or if it's too short. It seems like as the rear end goes up and down the shaft would need to move in and out, but it seems like it's barely on there to begin with. Maybe some of you can take a peak under your truck? Any advice is appreciated. This is stock suspension by the way.
Old 09-27-2013, 07:38 PM
smokenchoken's Avatar
smokenchoken
smokenchoken is offline
completely normal friend it is around halfway point so its about right to deal with suspension movement not to worry next time you get the chance if i were you i would grease it and probably every other zerk on the truck it helps more than you would imagine
Old 09-27-2013, 07:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
That looks okay to me, it looks like it's about half way on the splines.
Old 09-27-2013, 08:04 PM
1975FordF250
Okay, that makes me feel better. This truck was pretty well abused so I'm going over everything. I will grease it like you said smokenchoken. Thanks both of you.
Old 09-27-2013, 08:11 PM
Jdeshler's Avatar
Jdeshler
Jdeshler is offline
I was worried about the same thing on a long bed 2wd I once owned.. I noticed it when my hanger went out but i was assured it was alright so i fixed it and drove it for years.. I agree you are all good
suzukibruce
1978 - 1996 Big Bronco
17
12-18-2009 08:57 PM
maxtruck00
1999 to 2016 Super Duty
05-22-2009 12:52 PM
Keepin It Real
07-24-2007 02:19 PM
Quick Reply: 1975 F250 Driveshaft too short?
