04-08 Super Duty Firewall differences (for dash swap)
How big of a difference is there between the 99-07 and the newer super duty firewalls? My reason for asking is I have been tossing up swapping over to the 08 dashboard and trying to reuse my 04 cluster for now(ill make it fit and look nice). I was wondering if it would be easy to modify the 08 metal support to fit my 04 firewall or if the firewall is what really needs to be changed. I planned on making the air ducts work buy piecing my old one and new ones together. I have manual A/C controls so i would use 08 manual controls which i personally like better than the auto ones. All the switches i planned on just cutting my current connectors and soldering on the 08 connectors so that they would still function. I'm assuming that the switches function the same just a different look like the 4x4, manual A/C and headlight switch which is all i really have anyway. I have the airbag switch but i never use it so if i lose it no big deal or i can even integrate it somewhere else. Also i have an aftermarket head unit so the radio is no issue to install i will just change the install kit to an 08 one. I have been searching a lot over the past few days and there have been a few people who hae done it but they either switch fire walls because its a wrecked truck or there is no pictures or description available as to what they did.
The following users liked this post:
Will do man I haven't been able to find anything so I'm gonna take the plunge myself and figure it all out. Do you have any idea if the metal structure behind the dash is similar or not to the 99-07 trucks?
Steering column has shipped does anyone know where i can find wiring diagrams so i can eventually swap it out and reuse controls? I got a wheel with audio controls even though i don't have it stock i will most likely update my AVH4400BH to have the audio control module and ill tie it into the OEM switches.
Does anyone have any pictures of the metal frame behind an 08-14 dash or can anyone point me in the right direction? I have been searching all day and the only thing i cant find is the metal frame so i can compare it to a picture of the 99-07 frame to see the differences. Once I see the differences I may start purchasing parts for the dash i found a few fairly cheap.
EDIT: I came across the differences between the two years in pdombrowicki's build thread.
Pics of 08: https://www.ford-trucks.com/forums/9...-10-ex-31.html
Pics of 04: https://www.ford-trucks.com/forums/9...-10-ex-36.html
I guess with some modification it will fit, the only thing that concerns me is the heater box or the big assembly (don't know the technical name) in the middle sticks out in the middle of the 08 but slightly off to the side in the 04. If i can get a look at the 08 metal dash structure i bet i could figure it out though. I have a feeling that the 08 metal frame will fir the 04 if i can rig up some mounting points or even if i could get the 08 dash to fit my 04's metal frame.
I got my steering wheel in today! (sorry crappy phone pics) To my surprise it came with the shift and blinker levers and the column cover so that's money i don't have to spend! Does anyone know where i can get wiring write ups or diagrams to swap the columns over? Also can i reuse my current keys in the new column?
does anyone know if i can replace this platic piece or do i need the whole assembly?
Also i contacted white Bear Lake Ford (Tousley ford parts) and asked them if they sell just the frame but unfortunately you need to buy the frame and dash panel. I am waiting on a response form them on the differences between years now and will post up what they say once they get back to me.
I plan to start installing my 08 Front door panels this weekend, the rear ones (ex cab) don't line up so i will have to modify them to fit but that will be another project. I heard back from Tousley and unfortunately they don't have the dashboards in stock to compare them for me. My plan is to purchase a new frame and plastic shell and then buy all the cosmetic parts on ebay since I will most likely end up painting parts of the dash to work. I am also planning on getting one of the newer floor consoles and replacing my 08 console with it. I am hoping that by getting a new dash and getting all the cosmetic panels i can get this done for cheap compared to buying a complete dash on ebay for $1500+ that's in good shape. Also i am going to try and use 2013+ switches because they have a blue lights which I had planned on eventually switching to anyway. This conversion will most likely not happen until next summer but I will continue to update this as i obtain the parts for this swap.
Tylus I will try and fit the new steering column as soon as possible for your reference. Once i find out how to remove it ill try and do it one weekend because i will continue to use my old column until i am ready for the complete swap.
