04-08 Super Duty Firewall differences (for dash swap)
#347
#349
#350
Hey guys I wanted to throw up an update on my fuse panel mount that i came up with. The original spot was not an option because it contacted the steering column and because the 08+ fuse panels are in the passenger kick panel now. What i did instead was trim the plastic to move the fuse panel approximate 1" down and 2" to the left to make just enough room for it to sit in its original spot and not interfere with the column anymore.
Before:
After:
I also got some nice door lock pins now I would recommend them except they sit flush with the opening when locked. Personally this does not bother me because using the door handle for the inside opens them but in a crew cab i might stay away from them or mount them more upwards so that in case of emergency they can be manually pulled up and the door can be opened.
Unlocked:
Locked:
I think they will look nice once the door panels are painted black as well.
Before:
After:
Unlocked:
Locked:
#351
Way ahead of you i already got the 08+ door panels on They door pins can be adjusted i just have them all the way down right now they are held on by a screw i just didn't feel like taking the panel on and off several times i will probably adjust it so it's half way next time the panels are off (today lol).
#352
You mean for using these buttons for audio controls? Do you have a schematic of the audio controls? Again, sorry if you posted it already and I missed it
#354
My thought was in order for the truck to know what each button is i need to remove the resistors in the 08+ board and replace them with the correct resistors that make them match the 04 resistances...i just realized i can remove the resistors in the 04 board...maybe ill check when i get home lol.
#357
Got a lot done today but after i got the truck started i went to shift into drive and the brake line blew so...my project is going to be slowed down never the less. I will be finishing up the truck but more slowly since it can; move now. I will be doing the brakes on my Expy and the fuel tank in my 95 first now so that i can get two out of the three fully up to date.
#358
Super duty
Great build. I have been following since day one. Have you been able to figure out the lighting and dimmer switch. Also you had mentioned a video about wiring up the windows and mirrors. Can you direct me on where to find. I seem to be stuck on those items and driving me crazy. Thanks for any help
#359
I'm still working on that I think I blew a fuse so I need to check before I start to check my wires again because logiczlly the way I wired it to me makes sense but I'll have to double check.
Im not sure about the video I'm not at my computer and it doesnt come to mind right now but what are you stuck on exactly? Getting the 08+ switches to work?
#360
