Tach hook up
Tach hook up
Not exactly a Ford question but I need help with my thought process.
I have an old Case Back-Hoe (that I pull w/ my Ford) that I want to put a Tach in. It has a 4 cyl gasoline engine that spins to 2300rpm. The tach I have goes to 8000, so trying to look at 1500-2200 will be difficult. However, the tach has a switch on the back for 4-6-8 cyl engines. If I install this and put the switch on 8, will it read 4600 when I am actually doing 2300rpm??
I want my max rpms to read around 60% or so of the face. I can "recalibrate" the face with a Sparpie marker.
RPM is proportional to the frequency of the switching waveform at the coil, call that FREQ, measured in cycles per second (Hz). For a 4-stroke engine, RPM = 120 * FREQ / CYL where CYL is the number of cylinders (4, 6 or 8). For a given frequency, RPM decreases as the number of cylinders increases. Therefore, 2300 would appear as 1150 if you set the switch to 8. The 4-cylinder setting is the highest you'll get.
You could just do like I did, and build your own homemade digital tachometer
https://www.ford-trucks.com/forums/1...tach-pics.html
MIKES 68 F100
10-30-2015 12:10 PM
79boston150
05-06-2009 06:43 PM
