SEARCHING FOR FRONT END SEAL!!!! - Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader:
Old 09-27-2013, 01:53 PM
RUSTYQ RUSTYQ is offline
RUSTYQ is starting off with a positive reputation.
New user here. have a 97 F350 crew cab diesel 4x4. workn on front end and havind issues getting a replacement dust seal for the front end dana 60. The seal goes at end of dif tube on the inside boss of the inner drive axle. I keep getting the same part number for the outer seal on the outer drive axle on the hub side. 710413. Problem is the inside diameter is to big. I need one w 2 1/8 id. The outside one is 2 3/8. Same seal just different id. Anyone ever have this problem? Dealer cant even find the right part number.
Dana 50 Outer Front Axle seal Identification ethand320 1987 - 1996 F150 & Larger F-Series Trucks 7 04-24-2014 07:14 PM
RUSTYQ RUSTYQ New Member Introductions 3 10-01-2013 09:53 AM
Front Axle Seal - Worth Repairing? IHbase 6.0L Power Stroke Diesel 25 02-27-2012 02:20 PM
Outer Axle Seal problems strokerengine 1999 - 2003 7.3L Power Stroke Diesel 4 02-26-2011 12:10 PM
oil seal help for 94 f350 dana 60 RRranch 1994.5 - 1997 7.3L Power Stroke Diesel 4 07-25-2010 06:12 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
