"MIL OFF" so truck wont pass smog visual
Went to smog cert my 2003 7.3 and found the check engine light doesn't come on with the rest of the indicator lights when the key is turned on. I never noticed as I don't rely on idiot lights, but apparently the state of California demands that check engine lights are functional to get a smog cert. the OBD shows no codes and its all stock with no aftermarket downloads and the inspection is visual only. So i need to figure out how to turn the MIL back on so it will pass smog. Ideas. Suggestions? If it was reading MIL ON and the light was off id suspect the bulb or whatever illuminates the check engine icon, but it reads MIL OFF. Thanks for looking.
See:
http://springerpop.net/F350/upfitters.html#bezel
First you have to remove the radio and take out two little screws at the top of the radio opening.
Then pull the dash bezel off, then unscrew the four screws that retain the instrument panel.
Be careful not to break the little thread that moves the transmission selection pointer (if your e-cluster still has that).
Pop
Pop
GOVTMOD
05-28-2023 10:00 AM
nebechanezer
12-08-2007 04:16 PM
GeneStoner
04-04-2003 09:08 PM
