'71 F-100 seat conversion ???
I'm going to upgrade the bench to a later model more comfortable seat. I know the 88-96 F-150 60/40 split will work but having a tough time loacting a donor. Would like a fold down arm rest also.
?? Anyone used anything else that works well and gives a little more room behind the wheel?
How did this seat config work for you? I am interested in the builtin shoulder belts.
on
I'm going to upgrade the bench to a later model more comfortable seat. I know the 88-96 F-150 60/40 split will work but having a tough time loacting a donor. Would like a fold down arm rest also. ?? Anyone used anything else that works well and gives a little more room behind the wheel?
That being said, my cousin had a 92 f150 with the bench seat and it too was nice. But my seat beats it.
I recommend you try out the foam sheet first. Any fabric/ upholstery material store should have it. Buy the 2" thick stuff and just lay it over your seat. You will be amazed how well it works.
As far as comfort goes, my seat is BY FAR the most comfortable seat I've ever sat on, and i get the same reaction from everyone that rides with me... It's the factory bench with a sheet of 2" foam laid over it the bottom and a saddle blanket seat cover.
I haven't been able to install them yet but I'm close. I've done a test mock up & it's probably going to involve modifying the existing mounts & then building a new bracket for the seats to bolt too which I will bolt to the factory mounting holes. I'll post an update once I get them installed.
