2005 ESOF hubs - is it big job?
I had the vacuum pump quit on my 2005 F250 4x4 so i assumed there must be a leak somewhere (pump smelled like burnt plastic) Using a vacuum pump I suspect it to be the RF hub as it won't hold any kind of vacuum while the LF hub will hold 15 lbs for a few minutes. How big of a job is replacing the vacuum seals inside the 4x4 hubs? 2005 F250 4x4
Take a look at this. It might answer your questions:
https://www.ford-trucks.com/forums/9...with-pics.html
