My 1951 Panel "refresher" build thread
Since my 52 is pretty much done, I decided to start on the 51. The Panel has been sitting for several years. It last ran probably about 6-7 years ago. It's in decent shape, but does show it's age. Since the truck came from Arkansas, it does have rust/rot in the usual places. There are patch panels in the front floor, rot in the rear quarters, rear doors, front fenders and front cab corners. Throughout the years, I was smart enough to buy good body parts for this truck whenever I came across them.
Years ago, I purchased what was then a completely solid front clip to replace the one in this truck. Since the clip was sitting outside, it has now developed some rot in the running board areas, but not extremely bad (about quarter size hole through just the fender sheet metal and not the reinforcement). This will be an easy fix. I also came across a pair of rear doors in solid shape. I had to buy another Panel truck just to get a good right rear door. The left rear door (not installed) was purchased in SoCal several years ago for $75. I plan to have all replacement body panels repaired and refinished in the same color as the truck is now (or as close as possible). I also need to replace the running boards and have several pairs of solid boards. The front bumper is also getting replaced with a better one.
First order of business was to replace the wheels. I kept the 15" wheels that were on my 52 Panel, which also had new rubber installed before I removed these wheels from the 52. I also installed the poor man's spider caps. Still need to get some beauty rings for the wheels.
Before
After
The plan is to do a budget build. I don't want to modify this truck in a way that would make it hard to return to stock. We got the flattie turned over today after replacing all of the tune-up components. We couldn't keep it running because the truck is possibly out of gas or the "new" replacement fuel pump wasn't working. I have a 6v electrical pump on order. The good sign is that it had a healthy crank. I also have 1/0 cable and battery post connectors on order to replace the rotted out cables in the truck now. I'm hoping that the flattie will still be good enough to run as is. I can't afford a rebuild right now. With the work/parts it needs currently, I'm hoping to stay under $3k.
The plan is (in no particular order):
Even though I'm not a newbie, I'm sure I'll be asking a lot of questions during this build.
Before
After
- replace front fenders
- replace running boards
- replace front bumper
- replace rear doors
- replace rotted out battery tray
- replace (maybe) front cab corners
- remove dual vacuum w/s wiper motor and replace with 6v electrical motor
- rewire entire truck
- fix stock horn button
- install stock radio/speaker
- install 9" rear and air shocks in rear
- maybe lower the front end either by removing a few leafs or adding a drop axle
- insulate interior
- change out the door glass division bars and vent windows with s/s and chrome from a Deluxe truck
- repair Magic Air heater and install new fresh air tube
- letter the sides of the Panel with my father-in-law's business (already have the vision of the lettering/logo in my mind)
We got her started and running yesterday. Also did a compression test. Right side from front - 110 90 90 90. Left side from front - 110 dead 110 110. Hopefully, the dead cylinder is not a real big issue. We're hoping that it's just a stuck valve, or maybe even a bent valve. Any other ideas why the cylinder is dead? It also sounds like there's an exhaust leak on the right side. I shouldn't have sold the good flattie exhaust manifolds I had a while back, but this gives me an excuse to buy some headers.
The flattie has a healthy start and appears to run smooth. I measured the voltage on the battery while the truck was running and it was 6.88, while steadily climbing up. The generator still works good, but I may replace it with a 6v pos alternator. I may also add a Pertronix coil and ignitor.
Click on the images below to see the videos.
My friend will be gone for a week, so I'll be concentrating on the body and whatever else I can do without him. He's the mechanic guru.
