5.4 3v timing chain tensioner swap - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Log In
Old 09-25-2013, 08:17 PM
eggman36075 eggman36075 is offline
eggman36075 is starting off with a positive reputation.
Question 5.4 3v timing chain tensioner swap
I have an 07 f150 with a 5.4 3v with 165k miles. Going to be replacing the timing chains, tensioners , and guides soon. I know the 07 has o-ring sealed tensioners, but can I use an 04 and earlier steel backed tensioner when I do the job? Cloyes makes a "high perf" model available from summit, but only says up to 04.
Old 11-05-2013, 08:09 PM
Varsity Tyler Varsity Tyler is offline
Varsity Tyler is starting off with a positive reputation.
I have rear of other techs using the old style (non-gasket) tensioners without issue, but I've not seen it in person.
Old 08-02-2015, 10:49 PM
Reid Krabill Reid Krabill is offline
Reid Krabill is starting off with a positive reputation.
Quote:
Did you ever use the iron tensioners?
Similar Threads
HELP!!! Tensioner Backing Plate Required??? HappySailor Modular V8 (4.6L, 5.4L) 0 12-09-2014 05:40 PM
Timing chain and tensioner kewing75 2004 - 2008 F150 1 02-28-2014 10:10 PM
Timing chain tensioner issues Fordzilla5.4 Modular V8 (4.6L, 5.4L) 1 02-02-2014 12:30 PM
04 5.4 3V timing chain and cams upgrades 76fordguy Performance & General Engine Building 0 03-26-2010 08:00 PM
Timing chain tensioner bjboyle 2004 - 2008 F150 27 01-20-2009 06:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
