D50 spindles
D50 spindles
I'm replacing front bearings and races, I thought I'd replace the spindle bearings and seals too since they have probably never seen any service since new.
Is there a trick to get the spindles off ? Mine seem like their welded on. PB Blaster and a dead blow hammer aren't doing the job.
on
1 Post
There is a step flange on the back of the spindle that goes through the hole in the knuckle. That's where they get stuck. Just gotta keep soaking and pounding. I have turned the wheels all the way to one side and used a long punch and hammer to hit them from the back, but it's hard to do.
They make a tool for a slide hammer. It threads onto the spindle than you use the slide hammer to pull them off. Works like a charm and doesn't risk ruining anything
OEM/4WD spindle puller (27104) | 4WD Spindle Puller | AutoZone.com
Get the tool that Brad linked to. I pulled the spindles on my D44 with a couple hammers, punches, and screw drivers. it took almost all day just to get them off that way.
I used the slide hammer attachment on the last D50 I did and it took three good hits with the slide hammer on each side.. so 10 seconds per side? Lol
arkredneck
10-24-2011 12:06 AM
Slow96
09-04-2009 12:40 AM
tetraruby
03-08-2003 11:00 PM
