1997 - 2003 Radio Bezel
Old 09-25-2013, 04:44 PM
vf150's Avatar
vf150
vf150 is offline
Question 1997 - 2003 Radio Bezel
I have a 98' f150 with a radio bezel without a temp control divider. Will a radio bezel from a 97', 99', 00', 01', 02',03' with a divider fit in place of the 98' bezel?
Old 10-05-2013, 12:13 AM
vf150's Avatar
vf150
vf150 is offline
No one knows? Oh well, I'll just try it. Thanks.
Old 10-06-2013, 08:06 AM
98_F250's Avatar
98_F250
98_F250 is offline
On my 98 the dash has a top-centered support bracket that prevents the radio from going beyond 3 inches back on the upper 1/3rd of the stock radio. This bracket can be unbolted if are willing to remove the two bolts holding it on the face of the dash and remove the rear bolt(s) also. When you slide out your stock radio you will easily see this bracket. I think they removed this bracket in the 99 and later models.
I used a $8 ebay kit that had a 3" upper pocket with a standard sony stereo.
Old 10-07-2013, 12:51 PM
vf150's Avatar
vf150
vf150 is offline
Talking
98_250 Thank you for the information. The bezel I was referring to is the dash bezel that surrounds the radio and temperature controls. My descriptions of a problem do get confusing at times. Thanks again.
Old 10-07-2013, 01:01 PM
vf150's Avatar
vf150
vf150 is offline
Though an extensive search was done on site and no information found, I took a chance and rolled the dice. The dash bezel with a divider between the temperature controls and radio does fit where the bezel that had no divider was. FYI
Texascowboy77
07-08-2018 10:33 PM
booffer
09-12-2017 10:14 PM
Shadowrider123
16
11-15-2012 06:27 PM
wrestlingterp
1997 - 2003 F150
09-25-2005 03:36 PM
MBeckster
04-17-2005 09:44 AM
Quick Reply: 1997 - 2003 Radio Bezel
