429 engine help!! - Ford Truck Enthusiasts Forums
429 engine help!!
Old 09-25-2013, 05:16 PM
Monsterford34 Monsterford34 is offline
Monsterford34 is starting off with a positive reputation.
Unhappy 429 engine help!!
Hi, I got a 429 with a d0ve-a block and d0ve-c heads. As far as I know this engine is all stock and has never been tore apart. From what I have been researching it should have around 10.5 to 11.0 compression and everyone says that you cant even run 93 octane in this. Is it true? If it is, what would I have to do? My second question is what would be the easiest way to get up into at least the four hundred horsepower range?
Old 09-26-2013, 01:23 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Are you going to go through it or just run it?
For 400 horse, if you are starting with what was called a "Thunderjet" motor with 11:1 compression, you just need a cam and probably a good set of headers. Maybe a little bigger 4bbl carb. They were rated at 360 hp under the SAE gross HP ratings. Net is supposed to be 80%, or 288 horse, so perhaps the 429s we under rated a bit, and the net is closer to what they actually claimed.
You are not alone:
ford 429 more hp - Hot Rod Forum : Hotrodders Bulletin Board
More background, note most who are going to build a 385 series motor for power go 460 or bigger.
Big-Block Ford 460 Engine Build - Car Craft Magazine
Old 09-26-2013, 11:02 AM
Well I am planning on checking everything out before i put it in so I'll probably put new gaskets on and all the small stuff. I knew that they were rated for 360 hp and figured that it wouldn't be hard to get to 400. You were saying about 288 hp, Which one do you think is more accurate? Plus, will i have to run gas above 93 octane with the 11:1 compression?
Old 09-26-2013, 04:06 PM
They were rated 360 HP under the old gross rating system. The rule of thumb was about 80% for the later SAE net rating. 80% of 360 is 288, which seems low. HP ratings in the late '60s and early '70s were skewed by government and insurance pressures. Manufacturers would understate HP ratings so the vehicles in question would not be tagged for performance surcharges, or draw regulatory attention. The Boss 302 and Z-28 motors both test out about 360+ HP, but were both rated 290 HP. CJ 428s were rated 335 HP, while similar PI motors were rated higher:
428 CJ Horsepower - Vintage Mustang Forums
CJ 429s were also under rated, so the T-jet may have been fudged as well.
11:1 will be a challenge and you will be buying no less than 93 for sure.
Seems like there is some sentiment towards going 460 due to more piston choices, allowing a slightly lower CR. More info here:
Tech Topics - 460 Ford Forum
Old 09-26-2013, 11:46 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
Dove heads issue!
If this engine hasn't been gone into. The exhaust valves probably don't have harden exhaust valve seats. this engine in the beginning was for leaded fuel. Today's fuel isn't leaded, unleaded. will probably have some exhaust valves sucking up in the head soon. something to be concerned about. other than that 400 hrspwr isn't hard to make with this engine at 10 to 1 comp. 1 hrspwr per cube with right cam and intake and header. mild port work on exhaust. Work the bowl area as air comes into intake valve area and good things will happen. Ran this engine for yrs, still have! Been a trooper.
Old 09-29-2013, 06:42 PM
Okay cool. The guy I got this off of knew nothing about it as a guy just gave it to him. I am planning on taking the heads off to give everything a look. I did drop the pan and surprisingly it looked really good. All the bearings seem nice and unsurfaced plus the timing chain was still tight like it was new. But anyhow, so you are saying that I should change the valve seats? Also could someone tell me why I CANT run pump gas with this engine?
Old 09-29-2013, 08:59 PM
You can run those heads and chance that they will hold up to unleaded gas. Some engines last a long time, some suffer sunken valve seats in short order. You can pull your valve covers after a couple oil changes and see if you have any "high" valves.
You can run pump gas, as long as the pump is the highest quality highest octane you can find. You may have to retard your ignition a bit and be good, or you might get pinging/detonation and have to figure something else out.
I once talked to a fellow using two head gaskets on one of these to make it run without pinging. Not sure how that worked out, but I would think that would be a guaranteed blown gasket situation.
More "radical" cams bleed off cylinder pressure enough to allow higher compression, so if you are thinking of a cam, ask the cam maker about your engine specifics.
Run it "as-is" for a while. Costs you nothing, and you'll get a feel for it on pump gas etc.
Old 09-29-2013, 10:46 PM
Okay, Sweet. My plan is to just do the moderate things to it (cam, intake, carb, headers). I just want to tune it up a bit so I have a nice motor that will have some nice kick to it.
Old 10-01-2013, 11:04 AM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
another option is since you are taking the heads off anyways, is swap them for the later D3VE heads with the bigger chambers. this will lower your compression into the 9 to 9.5 range and you will get hardened seats also. there is very little difference in port designs between the two, so performance won't suffer due to the ports. both heads really benefit from porting work especially on the exhaust side (check out Reincarnation Automotive for a guide on how to home port these heads, costs about 25 or 30 to register but well worth it).
the big difference between the heads is that the DOVE heads used screw in rocker studs with positive stop studs while the D3VE heads used bolt down pedastal style rocker arms. if keeping the D3VE rocker arm system on the DOVE block, you will have to measure for correct pushrod length. you can get them machined down to accept aftermarket studs and roller rockers or there are kits out there that convert them to adjustable roller rockers without machining.
that would be a easy way to let the motor survive easier on 93 octane gas. have a 70 460 and even on 93 octane when i step into the pedal it will ping pretty good, but under most normal driving conditions it behaves nicely on 93 octane.
my 2 cents
Rgds
Mike
Old 10-04-2013, 09:12 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
I have never personally done it but Call Rich At circle R in IL. He has ran a ton of dove heads WITHOUT hard seats, even on the strip. He claims that the hard/soft seat issue is nothing more than hype created by machine shops to get a rebuild out of a guy that may not even need it. If your seats fail, I highly doubt it is because of lead/no lead. It is probably because that thing is like 45 years old. The 429 thunder jet was either 320 or 360 and the CJ was 370, The super CJ isn't even listed in my book, for HP that is, neither is the PI. The CR is specd to 10.5:1 and if that is actually correct, you might run on pump premium.
Remember that some of these engines have been torn down that didn't have 10.5:1 factory, and it has been claimed that with deck heights and gasket thicknesses, some have been found that didn't even have 10:1. If you are dead set on this, run a cam with some overlap and that will help run on our gas today. dumps some compression.
Old 10-06-2013, 11:31 PM
wyoming4x4's Avatar
head issues.
When looking at your valve seats look and see if all are even on height. harden exhaust seats will become a issue if driven a lot! I have had valves suck up. if valve sucks up into head and you don't catch you will probably drop a valve and do some serious damage. If new harden seats installed and machinist cuts into to far can cut past harden material and this will also cause your seats to wear abnormally, suckuped valves. If running agressive cams this will possibly cause things to happen quicker. things i have learned along the way over the past 20 yrs. Proper valvespring pressure is a must per cam also. good luck and 429 is a good engine i ran for many yrs. I still have mine for a spare. Run solid cams in my 429 and 472 and 520. Basically SCJ big blocks. They all make more than the factory SCJ from back in the day. The PI (police inteceptor)heads work well also with some cubic in under them, thinking 500" would be nice. have a good evening.
Old 10-08-2013, 07:33 PM
BigBlockF350's Avatar
BigBlockF350 BigBlockF350 is online now
BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.
May be hard to run it on pump gas. I was recently dealing with a similar engine (same block and heads), but it was a 460. On 93 octane I couldn't get it to stop pinging with the vacuum advance hooked up. With the advance unhooked and the engine re-timed, it wouldn't ping, but I didn't get as good of gas mileage (like 5 mpg) and it wasn't as responsive as I would have liked.
With these engines when you go getting a little above 10:1 compression, everything has to be right to keep it on pump gas and still run it with efficiency (well, as efficient as a big block will get) on the street. The D0VE heads are good for making power, but they also get hot and can be a contributing factor for detonation. The engine I'm working with now has D3VE aluminum heads, which are also a fairly good design and dissipate heat better. These can support 600HP+ ported correctly.
If you have issues with detonation, you should also look at other factors like trying to get the coolest air into the intake. You may need to run an intake hose to your air cleaner to get cold air. You can also take the intake off (you'll be there while doing a cam swap) and block off the exhaust cross-over port to help keep the intake cooler to keep intake air temp down.
Various spark plug heat ranges can also help reduce detonation.
Best of luck with your project!
429 thunder jet in a '79 crew Wyofordguy Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 10-10-2016 07:42 PM
460 Cylinder Head Swap? rudifisk 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-23-2015 12:54 PM
i want to put a 429 in my 93 f350 429thunderjet93f350 1999 to 2016 Super Duty 2 03-26-2015 10:01 AM
429 engine block casting numbers fordnutz66 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 09-09-2011 09:08 PM
1969 429 intake questions (casting numbers I.D.) gingerbreadmaniac Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 12-13-2008 09:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
