Hitching aids
Old 08-27-2014, 10:58 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
My truck never made it off of the dealer lot befor that center headrest came out. My wife's Fusion at least made it home first. DOT regulations say that manufacturer's supply one for each seating space - regardless of the fact that the blind spot may be a worse driving hazard then the headrest.
Old 08-27-2014, 01:19 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Ditto !!!
I have TWO center headrest in my storage building
Old 08-27-2014, 01:29 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is online now
Since my backseat is full of carseats, I have all three of the headrests taken out. Rearward visibility is much improved.
Also, another marriage saving solution is to keep your wife away from you whenever you are hitching up, or backing up the trailer. I decided a couple of years ago I'd rather damage the trailer by backing it into a tree then hve to listen to her yell at me. I usually have to get in and out of the truck a bunch of times, but that's easier, and often faster, than getting her to "help".
If at all possible, I try to hitch the trailer when she's busy doing something else.
Old 08-27-2014, 02:43 PM
blackgold50's Avatar
blackgold50
blackgold50 is offline
I'm learning this now.. My wife tells me after I'm at the hitch and 4" to one side to say I am off. When I say that she should be directing me as I'm backing up to be on it, she can't tell where it will be so she doesn't. When I bring our toy hauler home, I back it up to the house if it will be with us more than a day. OMG That is more frustrating than hooking the trailer up. SHe gets all frustrated saying it makes her nervous and that frustrates me and it's just a big cluster...
Brian
Old 08-27-2014, 02:56 PM
senix's Avatar
senix
senix is online now
Received 1,416 Likes on 1,011 Posts
I have the wife yell for obstructions only, no other help.
Old 08-27-2014, 03:11 PM
blackgold50
That would probably be wise but I have to come in at a bit of an angle and straighten up to the edge of the house. SHe'd still find a way to get flustered! lol
Brian
Old 08-27-2014, 04:37 PM
meborder's Avatar
meborder
meborder is offline
wow ... i got it good.
my wife usually hooks her own trailer, and when she helps she tells me which way the ball has to go, waves me back and clenches her fist and says "whoa" when i need to stop.
then i sit there with my foot on the brake while she drops it on the hitch .....
Course, it helps that she knows how to back and hook up, so she knows what the driver needs for help.
sounds to me like you guys are doing something wrong just gotta make them back up and hook up with you standing there telling them they are off when it is too late to do something about it
Old 08-27-2014, 04:41 PM
Irelands child
Sounds like we all either married the same woman or one of them was cloned. Mine usually stands in a blind spot waggling her hands or cringeing if I'm really close to an obstruction.
I have no problem hooking up our 5er, but those obstructions while backing can play h3!! with fiberglass - and the new one is significantly longer then the last, especially with the extended pin box location now on most 5ers
Old 08-27-2014, 08:30 PM
Archion's Avatar
Archion
Archion is offline
The headrests on the wife's Escape came out as soon as we got home, been in the closet ever since. The dogs don't need em.
Old 09-15-2014, 08:21 AM
lariat97's Avatar
lariat97
lariat97 is offline
I don't look out my rear glass to hook up a trailer. I use my mirrors. If I'm backing straight onto the rig I center the trailer by having the same amount showing on both sides. I've towed so many years I can get on the hitch without ever looking out my back glass. Trust your mirrors.
Old 09-15-2014, 08:27 AM
Mystic_Cobra's Avatar
Mystic_Cobra
Mystic_Cobra is offline
Howard-
Does this work for you with a gooseneck, too?
Old 09-15-2014, 09:15 AM
jdadamsjr's Avatar
jdadamsjr
the problem is the headrest blocks the view using the rearview mirror on the new trucks too
  #28
Old 09-15-2014, 12:50 PM
seventyseven250
Pretty sure he means side mirrors. Hopefully your headrests don't block those . . . .
  #29
Old 09-15-2014, 02:31 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
But every time I look at the mirror everything is reversed!!!
speakerfritz
1999 to 2016 Super Duty
04-06-2015 06:49 AM
jstange2
6.7L Power Stroke Diesel
13
03-21-2012 11:25 AM
RRranch
16
01-15-2011 08:33 AM
gr8scott72
09-05-2009 09:26 PM
ninerref
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-10-2005 10:40 AM
Quick Reply: Hitching aids
