Firewall fuse block short some where. Suggestions wanted. - Ford Truck Enthusiasts Forums
Old 09-25-2013, 12:58 PM
finitetime finitetime is offline
finitetime is starting off with a positive reputation.
Something has been draining my batteries. I traced it to a wire that supplies power to the fuse block on the driver side fender well inside engine compartment. It pulls .5 amp and I can't find it.
Test were done with amp meter between neg post on one batt and neg bat cable. Other battery is completely disconnected.
I unhooked everything from battery and then hooked up wires at relay one at a time until i found one with a draw. Turned out to supply power to fuse box on other side of engine compartment.
Moved meter to other battery leaving only one wire hooked to relay and pulled all the fused and relays. NO change.
I turned key on and have no power anywhere in cab.
What will pull power but not go through a fuse???
Does it feed on to the inner fuse panel?
Any suggestions on where to look?
Old 09-25-2013, 02:19 PM
I found it. And I lost it Its fuse. It's Maxi fuse S which said see fuse 4, 8, and 16. Also see Circuit breaker 12.
Only problem is it's not drawing power now. I pulled it in an out several times and watched the meter go up and down. I went to move the meter around the other side of hood so I could see it from inside the truck. Pulled the cover off the inside panel. Got my paper to check and see which fuses to check and glanced at amp meter and realized it read zero.
No blown fuses. meter connections good. Wiggled wires. Door. Truck. Thought about my big hammer in tool box. I give up for today.
Old 09-25-2013, 08:05 PM
tecgod13 tecgod13 is offline
tecgod13 is gaining momentum as a positive member of FTE.tecgod13 is gaining momentum as a positive member of FTE.
Maybe it was a little bit of corrosion or gunk on the fuse, or in the fuse block that was shorting across the fuse and causing the draw. Pulling it in and out a few times might have cleared that up.
Old 09-26-2013, 12:43 PM
ifrythings's Avatar
ifrythings ifrythings is online now
ifrythings is gaining momentum as a positive member of FTE.
Fuse S supplies power to:
fuse 16 -
cig ltr
CB 12 -
power door locks
power lumbar switch (if your seats have that)
Elec. shift control mod. (if your transfer case is elec.)
Fuse 8 -
Engine comp lt (was the hood light on?)
Pson inst clustr (that will draw less then a mA)
Radio (that can draw a bit when power is first applied, could be what you saw, will draw less then a mA when off)
Glove box
Door switches (was the interior light on?)
inside cargo light
Power mirror switch
Map/dome light
Courtesy light
Fuse 4 -
Running lights (that would be several amp draw.
If you have an after market stereo in there, they will always cycle the cd mech when power is first applied which could be what you were seeing on the meter.
Also does the truck have a remote start or alarm in it? they can go bad and kill batteries.
Old 09-26-2013, 12:46 PM
ifrythings's Avatar
Quote:
Not likely, that fuse would be getting rid of 6Watts of power, it would get pretty warm and look all melted or discolored.
Old 09-26-2013, 10:54 PM
Went looking for it again today. Couldn't find it at first and was giving up and putting wires back on solenoid when one sparked a little bit.
It was drawing from the 2 red wires that become one and go to the glow plug relay this time. It was 2 white wires yesterday. I'm thinking it might be in the switch or relay that is just not turning the power off. Its pretty strange that its a different wire.
I looked up ignition switch on auto zone site and it showed me a large square box that looks like a giant relay. Where does that go. I was expecting something you would shove a lock and key in.
Considering just running everything through a 100amp relay and put a toggle switch in dash. Key would just be to start it then.
relays continuous duty 12 volt & 24 volt DC power relays,starter relays
Power Distribution Box boomcyl 1999 - 2003 7.3L Power Stroke Diesel 5 08-17-2016 06:32 AM
HOW TO: Swap AMP meter to VOLT meter JimsRebel '80-'86 HOWTO's 11 10-25-2014 08:43 PM
Adding an auxillary fuse block - any one done this? 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 13 05-23-2013 11:04 AM
Keeps lilling battery, narrowed it down to this fuse... icantdo55 1997 - 2003 F150 8 03-16-2011 05:33 PM
blowing MAXI fuse in power distribution box??? FORDPLA 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-18-2000 06:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
