IDI Turbo/T-cases/Misc Parts
Category: Drivetrain
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000
Item Condition: CA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
I would say the best use for this unit would be a center housing assembly replacement for a worn/failed turbo - I strongly suspect that th proper exhaust housing found fix the low boost issue I had. Alternatively, it did work well in it's current condition.
The unit was removed to upgrade to a HX35.
$250.
3) Slip yoke styple 13-56 t-case. Used unknown condition removed from a junkyard truck. I expect it's in good shape and usable but I can't say for sure. Was bought as an emergency replacement for the truck but I never used it due to driveline issues.
$100.
4) Used hydroboost/1 5/16" master cylinder assembly. Removed from a junkyard F-superduty, appears to be in good shape. Includes the brake line adapter fitting and hydroboost to steering box hose.
$125
5) Homemade turbo intake hat - built from a steel pipe cap with a 2" nipple welded in. Worked well with my homebrew turbo setup but a bit oakie looking. I also have the turbo to hat pipe, but it'd only be useful with a similar homebrew setup.
$20
6) Good used vacuum pump with pulley. Removed due to hydroboost conversion but worked well before. I *think* this was a new replacement unit ~5 years ago but can't remember for sure.
$50
7) Good used vacuum brake boost unit & ps pump.
$10 ea
