couple questions
Old 09-25-2013, 07:52 AM
TedHJ's Avatar
TedHJ
TedHJ is offline
couple questions
What is the main difference between the '94.5-'97 and the '99-'03?
Did Ford not produce diesel trucks in for the model year '98?
Thanks
Ted
Old 09-25-2013, 10:08 AM
Smokiesman's Avatar
Smokiesman
Smokiesman is offline
If I am not mistaken they started building the 99 in 98? Maybe someone here knows more details?
Smokie
Old 09-25-2013, 11:15 AM
Mr. Finch's Avatar
Mr. Finch
Mr. Finch is offline
from my understanding when they redesigned the trucks, 98 only had the f-150 and the f250 pickups, then in 99 they had the f250 "pickup" and the f250 "superduty" and the f350 superduty now available with the v10 and the 7.3 was again available. then in 2000 the 250 and 350 where officially the "superduty" line as we know them now.
so no, the 350 (and diesel engine) where not available in 98 as they where going through the redesigning/prep for the transformation from "pickup" to "superduty"
Old 09-25-2013, 11:57 AM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Also, the 98 F250 was known as light duty. You will see these most often in junkyards. They look just like the 97-03 F150 but they have 7 lug wheels. And no, that is not a typo.
Old 09-25-2013, 12:02 PM
dsquared's Avatar
dsquared
dsquared is offline
Pete: I've seen a few of those 7-lug pickups around. Tried to rep you, but......
Old 09-25-2013, 12:24 PM
Mr. Finch's Avatar
Mr. Finch
we have had a problem around here from people stealing those rims since ford only used the 7 lug for those 2 years.
Old 09-25-2013, 02:35 PM
rufushusky's Avatar
rufushusky
rufushusky is online now
Thanks
Ted
https://www.ford-trucks.com/forums/1...duty-7-3l.html
See above, injectors are different, fuel pump is different, turbo is different, 99+ are intercooled, 99+ are all solid front axles, 99+ have unit wheel bearings etc etc...
Old 09-26-2013, 09:31 AM
TedHJ's Avatar
TedHJ
TedHJ is offline
Sounds like a '99 truck would be a fairly large advantage over a '97.
Agree?
dreamofford
1999 to 2016 Super Duty
09-17-2017 07:17 PM
carlos1212
15
03-18-2009 10:33 AM
71mustang
06-08-2005 10:48 PM
JudyK
04-15-2004 12:37 PM
Fordiod
10-01-2002 03:06 PM
Quick Reply: couple questions
