New born with broke down truck 911 White smoke - No power- Ping noise in valy - oil in exhaust.
#61
The RPMs turning at 2400 at 70 mph means you have a 4.10 geared rear end. It won't hurt anything in the engine regarding mechanics. And I now see that this question has already been answered.
#62
#63
Do yall think that was the problem???? None of the others appear to have anything wrong with them?
#64
Fuel coming out the exhaust will absorb the soot in the pipe along the way and appear to be oil once it starts to drip.
Are you sure it's oil and not fuel?
I'd start with injectors or fuel stuff.
When an injector blows a nozzle, or comes loose in the bore, it has a lot of the same symptoms you described. It would explain the white smoke and fluid out the exhaust. I've also heard a truck knock with a blown nozzle, too.
You can't unplug the injector thinking it will kill the issue, either. With the truck running and pumping fuel, there would be fuel dumping in the cylinder all the time, you can't shut that off without turning off the engine.
If it were me I'd start there.
I can't seen an IDM or electronics causing a smoke situation, that would be more of a dead miss, etc. Smoke is mechanical, IMO.
Keep us posted.
Edit: Having said all of that, we had a truck come in a few months back with 2 broken push rods. LOTS of smoke, poor mpg, loss of power, and some weird sounds coming from the engine. 1 rod was snapped in 2, another was 's' shaped.
Keep us posted.
It amazing that a little o-ring like that could slow down such a powerfull engine like a powerstroke!!!
#65
#66
I think I know what happen to cause this.The P/O Said the injectors had been rebuilt.
The bad injector was (Passenger bank Cylinder# 8) When I popped it lose and tried to slide the injector out it hit on the accumulator box for the A/C - Im pretty sure someone seen this and thought they would have to remove the whole A/C box (I thought so at first)So they just bypassed that injector.
I removed the service door on the box and was able to slide the injector out the rest of the way.Np. Guys thanks very much.
I have been working on a phone APP that telaports beer from one phone to the other - as soon as it is done yall will al get a free beer.
Next app im working on is the one that alerts you when your baby has soiled there dipper!
Thanks guys! Ill let yall know how it goes.
#67
#68
It's the fact that the injector was not properly installed and came loose, and combustion gases blew away the copper washer then the lower o-ring and drew massive amounts of fuel into the combustion chamber which it could not fully burn. Unfortunately I see that at least a couple times a month. You want that injector replaced, or at the very least a new nozzle and other components replaced inside. The excessive heat from all that fuel getting into the combustion chamber super heats the nozzle and other parts to the point they will become brittle. You don't want those pieces coming apart and causing even more issues later on.
If you got that other set super cheap, throw a set of orings on one of them and give it a try. I'd put the 'new' injector in the forward most cylinder to make it easier to change later if it gives you an issue later.
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
#69
Guy - i got the injector all in place except for the trouble maker- #7.
Im pretty sure I have mixed up 2 of the injectors (Iv got the trouble maker in the front port - passenger head and the one that should be there is ready to go into the rear wear the trouble maker should be . What will happen if Iv mixed up the injectors?
Also I have not installed trouble maker #7 because I feel part of the seal might still be in the port - Also The cooper peace that goes on the tip on the injector was missing - I installed a new one on the injector but fear the cooper peace maybe still inside the port. So I need to get them out. Any idea how. Its at a bad angle - to the point you cant see inside the port.
#70
#71
#72
#75
Update. Got all the injectors back in - Started the truck and sounds/Runs great! It sound way better then it did before (It always had a slight missfire until it warmed up before) Now it sounds awesome.
It did smoke for about 10mins but has stopped.
Iv got a new issue and not sure what to do about it.
When You go to start the truck - it doesn't fire up the first crank.
You can crank it for 10-15 secs straight and it wont fire - If you let off the key and hit it again it will fire right up (There is no rough idle or jump/bogging to it - It will fire right up.
The truck will not start the first time around.
I wounder if I knocked a glow plug out of place?
