1989 Aerostar 3.0 Rough Idle - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 06-18-2003, 11:31 AM
Stoney57 Stoney57 is offline
Stoney57 is starting off with a positive reputation.
Post 1989 Aerostar 3.0 Rough Idle
Hi, I have a 1989 aerostar extended van with 3.0 liter. It has a rough idle when I'm sitting at a stop light. It has never stalled yet and it has TONS of power when I want to get up and go. I have changed the wires, cap, rotor, plugs(have scars to prove it), fuel filter, and ran some fuel injector cleaner through it. It has been running for the past 40,000 miles like this and is not getting worse, is it time to maybe replace my fuel injectors? It has 184k on it right now and I would like to at least make it to 250k Also does anyone know what rear end gear ratio these vans have? 3.73 4.10 ?
Old 06-18-2003, 03:32 PM
Mikeman Mikeman is offline
Mikeman is starting off with a positive reputation.
As mentioned in a recent post, also replace the PCV valve. It's cheap so there's no reason not to. Another thing to consider would be the MAF/MAP sensor (not sure what was used in '89). Clean the throttle body and the idle air circuit and valve. Some people have found that a rough idle was caused by an idle speed that was too low. And, if you've checked everything and still can't figure it out, run a compression check. I chased a rough idle for a long time, and unwillingly went to two shops, only to find that I had a bad valve, which was revealed by a leakdown test.
Injectors could be the cause, but you shouldn't have to replace the fuel injectors unless they have failed. They can be cleaned with an ultrasonic cleaner for less than half the cost of replacing them, but you'll need to remove them. I found a shop that charged $17.50 each, but the more typical price is $25-$30 each.
1990 ford Aerostar 4.0 Liter turkin73kk Aerostar 5 12-28-2013 12:52 AM
89' Eddie Bauer 3.0L Transmission problem? Metallic Blade Aerostar 1 10-27-2007 04:49 AM
Thinking About Buying an Aerostar, Few ?'s Rowsdower98 Aerostar 23 12-17-2005 02:16 PM
Extended length conversion Aerostar info wanted MarlboroKlingon Aerostar 6 07-13-2005 03:39 PM
Idles / stalls / runs bad when wet shagnwagn Aerostar 2 02-17-2004 09:51 PM
Tags
1989, 30, aerostar, gear, ratio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
